20 Most Recent
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Questions & Answers
Picture comes on than turns off and red light stays on
you can reset the tv to factory default settings , but before that I need more info
ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem,
hope it helps you .
let me know
New Mitsubishi tv lamp isn't plugging in to make
you have to make sure you get the plug on the lamp fitting sits right so it will go home to the other end. make sure its not broken or moved as it will not locate on to the other end when fitting.
Mitshubishi WD-62327 TV will not turn on and no sound. TV made a interference sound and shut off. Tried to turn it in the morning still nothing. Replaced lamp/bulb still nothing. Red light is on
If you have a voltage meter there are some things you can check.Unplug the unit and remove the back cover of the set. Then Plug the unit back in.You will need to tape down the lamp safety switch in order to do these tests.Here are all the failures that would give you a lamp error and what to check.Cause 1. Unit powers on and works properly for a while then shuts off with a red lamp led(lamp error). Suspect bad lamp and replace.Cause 2. Unit does not power up correctly and you have red lamp led(lamp error). Check the lamp enable line at connector J14 on the back of the light engine. If pin 6 does not switch to 5 volts after turn on, but your 12 and 5 volt supplies are good, then suspect a defective light engine.Cuse 3. At power on the lamp turns on and off 3 times and then the unit shuts down with a red lamp led(lamp error). You have a defective light engine.Cause 4. Unit does not turn on correctly and you have a red lamp led(lamp error). Check for 12 volts at connector J9 pin 4 on the light engine. If voltage is missing check for an open fuse F9A09 on the power supply board. If it is open, then you need to replace the fuse and you still have a defective light engine.Cause 5. Lamp enable line at connector J14 pin 6 on the light engine does go to 5 volts at turn on, but does not drop back to 0 volts after 5 seconds, but your 12 and 5 volts supplies are good then you have a defective light engine.Cuase 6. Check for 5 volts at connector J9 pins 1 and 2 on the light engine. If low or missing check Capacitors C9A37 and C9A38. Values are 3300MF/10V. Replace capacitors if defective.This is all I have and I wish you luck.
