20 Most Recent Proview HV-207 20 in. HD-Ready LCD Television Questions & Answers
0answers
Need a remote code for Proview HV207
These are the setup codes for Proview brand TVs with GE universal remote control. If you want to know more codes and other details, check this link. Check these codes first.1025 1026
1/12/2013 4:03:26 PM • Proview HV-207... • Answered on Jan 12, 2013
I need to see a main board for my Phillips LCD tv Model # 40PFL3705D/F7
Sounds like a failed T-Con board, but hard to say without seeing the set.
12/16/2012 4:03:09 AM • Proview HV-207... • Answered on Dec 16, 2012
Need user manual
Try to locate the makers internet site or Google the model number with "manual" to try to locate it yourself.
6/15/2012 5:05:53 PM • Proview HV-207... • Answered on Jun 15, 2012
0answers
No signal, cable signal is good ,tried in another room still says no signal
Reset the TV. Refer to its user manual for details. If this do not help you, the turner might be defectve.
4/17/2012 3:52:14 PM • Proview HV-207... • Answered on Apr 17, 2012
I have a Proview HV205
This is the TV tuner and the manufacturer is XuGuang Tech Co. Ltd
9/4/2011 5:13:15 PM • Proview HV-207... • Answered on Sep 04, 2011
Tv proview hv207 problem
DON'T EVER BUY PRO VIEW!!!!! THEY SELL JUNK AND THEN CHARGE A TON TO FIX IT...................
I called customer support and they said it is the receiver. I can't find one and they want $190 to fix this 1 1/2 year old TV. Mine is not digital so I can't receive broadcast in a year so mine is going out in the trash.
No they want sell parts. You can cut your losses or give them them more money. Good luck.
8/25/2011 4:44:31 PM • Proview HV-207... • Answered on Aug 25, 2011
0answers
Blue screen
Be the first to answer 7/10/2011 9:22:39 PM • Proview HV-207... • Posted on Jul 10, 2011Be the first to answer
Trying to connect antenna. Tv
Sounds as if you have a bad tuner. Can be tricky to replace if it is on a 2 sided board. If you are not comfortable with a soldering iron or electronics, I would have a certified servicer look at it.
4/8/2011 12:42:27 PM • Proview HV-207... • Answered on Apr 08, 2011
I purchased at yard sale.
Look at the power connector on back of set. You will probably see 3 recessed prong's. You should be able to use the same type of cord as on a computer or monitor. You can get one at
any home center or electronics store like Walmart, BestBuy, hardware stores, etc.
3/16/2011 5:29:38 PM • Proview HV-207... • Answered on Mar 16, 2011
When I turn my tv
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly. The capacitors are blow and once replaced this will fix your issue.
Hope this helps :)
3/7/2011 2:30:15 PM • Proview HV-207... • Answered on Mar 07, 2011
Daughter put tv on av
have a look to see if the channel it should be on to use as a tv is still on channel 3 or 4.
8/20/2010 5:43:12 AM • Proview HV-207... • Answered on Aug 20, 2010
I need to purchase a main board for a Proview, MDL # HV205 LC TV.
Tries Websites Shopjimmy.com,Ebay.com should have this reburbish Main Tuner board.
4/14/2010 4:54:25 PM • Proview HV-207... • Answered on Apr 14, 2010
Proview 2020 lcd on/off surfs chanlels by it self, middle of night! Haunted?
I can't answer this question. But I want the opportunity tell everyone...THIS TV SUCKS. THE SOUND IS TERRIBLE, YOU CAN''T HOOK UP HEADPHONES. I WOULD NEVER RECOMMEND THIS TV!!!!!
12/27/2009 11:54:58 PM • Proview HV-207... • Answered on Dec 27, 2009
My remote control for my
Call Encompass Parts Distr 1-800-638-3328 Also look on back of TV for correct Model number give that # to them and Mats Electronics is another company 1-800-628-1118
11/27/2009 9:22:36 PM • Proview HV-207... • Answered on Nov 27, 2009
The touch screen is not
Hi
Thanks for using FixYa. If your remote isn't working then check for batteries in the remote, replace them. And, if you want to buy a new or replacement remote then you can visit this link--
Proview HV207 replacement remote
Proview HV207 Orignal OEM remote
And, if you have any other issue then please elaborate and descroibe the issue briefly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
10/17/2009 11:43:14 PM • Proview HV-207... • Answered on Oct 17, 2009
PROVIEW 19" LCD TV - FLATSCREEN - KV SERIES
I have same problem, im goin to try this fix i found on youtube.. different tv but same problem
http://www.youtube.com/watch?v=_0175VbmV9M&feature=channel
9/18/2009 4:30:33 PM • Proview HV-207... • Answered on Sep 18, 2009
4answers
Proview LCD TV
I am having the same problem. If I play with the power button on the back it will come on sometimes. I was looking for a solution here but looks like I will have to take it apart and check for loose solder joints.
9/6/2009 4:04:41 AM • Proview HV-207... • Answered on Sep 06, 2009
Proview HV-207 20 in. HD-Ready LCD Television Logo
36 questions posted
Top Proview Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proview Televison & Video
Most Popular Question
purchased yard sale
  • Televison & Video
