20 Most Recent Whirlpool NWF30945RS GAS RANGE FOR 220 VOLTS Questions & Answers
Where can I get a door for this stove online? Thank you in advance for your help
look for a used stove,parts arent made for them
5/7/2015 12:36:37 AM • Whirlpool... • Answered on May 07, 2015
Oven is sooting
Your gas flame is not getting enough air for combustion.
12/6/2014 8:24:35 PM • Whirlpool... • Answered on Dec 06, 2014
Burner flame is low
Get a service person to adjust the gas pressure. If done improperly you will be somewhere in the wild blue looking back at what use to be your domicile.
12/6/2014 6:56:55 PM • Whirlpool... • Answered on Dec 06, 2014
Sinkmaster 850 Garbage disposer. I have to unplug my Sinkmaster 850 to stop it the switch isn't working.
Question edited for clarity. Question moved from Cars and Trucks. Parts suppliers and the maker. https://www.google.com/search?q=sinkmaster+850+replacement+parts ..
4/12/2024 5:52:32 PM • Garbage... • Answered 3 days ago
2answers
Garbage disposal electrical shock.
Are you sure it wasn't a static electric shock, rather than AC? If you live in a dry climate, or in a cold climate without a humidifier, and you may have walked across a carpet, it could have been a spark of static electricity. Especially if it hasn't reoccured.
4/12/2024 8:40:38 AM • Garbage... • Answered 3 days ago
3answers
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
11/2/2022 7:28:51 AM • Garbage... • Answered on Nov 02, 2022
Removing viking 1030 garbage disposal
5/21/2022 11:43:46 PM • Garbage... • Answered on May 21, 2022
How do I unclog a T-1060 Waste Disposer
TURN OFF POWER before sticking your hand in.!! But first check the reset button underneath the unit. Also, try to rotate the spinner with hex key usually provided. garbage disposal 2-r5bj5m104gwgi1atksjipnx0-5-0.jpg garbage disposal-r5bj5m104gwgi1atksjipnx0-5-2.jpg
1/17/2019 7:14:36 AM • Garbage... • Answered on Jan 17, 2019
2answers
What is perspective of waste management by
Drink beer and then recycle glass bottle or aluminum can Then research recycling route for all recycled and non-recycled waste products If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/4/2018 10:41:22 AM • Garbage... • Answered on Dec 04, 2018
Does insinkerator have a start capacitor?
Yes... all motors have start capacitor .. ''Without a start capacitor when voltage is applied, the motor would just hum''
10/11/2018 5:44:15 AM • Garbage... • Answered on Oct 11, 2018
How to install a kitchen food disposal?
Go to utube and watch the film.
12/26/2017 12:43:53 AM • Garbage... • Answered on Dec 26, 2017
Unclogging garbage disposal
Hello, Tom -You may find this instructional YouTube video helpful:https://www.youtube.com/watch?v=qC8LN32ep_Q
12/22/2017 5:00:17 PM • Garbage... • Answered on Dec 22, 2017
My garbage disposal is stopped up how do I fix it?
Following link has step-by-step and illustrations: http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/11/2017 11:05:26 AM • Garbage... • Answered on Nov 11, 2017
How to fix leaking 901 sinkmaster
Following link has troubleshoot resources and step by step: http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/11/2017 11:04:41 AM • Garbage... • Answered on Nov 11, 2017
I want the manual for a Sinkmaster 850 garbage disposer
mnauls on following link: http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/11/2017 11:03:39 AM • Garbage... • Answered on Nov 11, 2017
Trouble installing GE garbage disposal. The cushion mount when installed per the installation instructions doesn't allow the enough space to set the hopper projections on the mount ring.
The disposal has to be lifted firmly ... place a block of wood under disposal to protect ... use small bottle jack to lift,, http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/11/2017 11:03:17 AM • Garbage... • Answered on Nov 11, 2017
Why does kitchen sink drain water from drain side to garbage disposal side
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
10/25/2017 11:54:34 PM • Garbage... • Answered on Oct 25, 2017
How do I unclog the pipe under my garbage disposer?
I am not aware of any that have a pipe under them can you tell us more
10/24/2017 5:11:07 PM • Garbage... • Answered on Oct 24, 2017
My garbage disposer stopped working - I can hear the engine hum when I flip the switch, but no part seems to be moving. Wondering if this can be fixed or if it's dead and needs to be replaced. Thx!!
Sometimes the disposal rotor is jammed by a piece of chicken bone for example. You can use the supplied hex key to stick into a hole at the bottom and jiggle the rotor free.
10/22/2017 8:07:00 PM • Garbage... • Answered on Oct 22, 2017
Whirlpool NWF30945RS GAS RANGE FOR 220 VOLTS Logo
3 questions posted
Top Whirlpool Garbage Disposals Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Garbage Disposal Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Garbage Disposals
Most Popular Question
get door stove online thank in advance
  • Garbage Disposals
