20 Most Recent
Toshiba 1370 Black and White Copier Questions & Answers
C5 error on toshiba 1370
Have you tried resetting the copier by unplugging it and waiting a few moments? If you problems persist check us out online for all your copier repair or
Copier Rental needs.
Code to put toner manually
BESOIN DE CODE DE TONNER =AVANT D'ALLUMER L'APPAREIL 0 ET 5 SIMULTANEMENT =AJ S'affiche puis tapez 90 PUIS PRINT UN NOMBRE S'AFFICHE exemple 75 TU VAS VARIEZ AVEC LES NUMERO 1 ET 7 POUR SORTIR 0 ET 9 SIMULTAN
Paper concertines up
HELLO WHAT JAI INCLUDING THOSE OF A QUESTION PAPER JAM = if the paper fits in the oven = problem = must clean separation or the ressord that holds fell, puts in place if it is a question of stuffing at the beginning of cycle = ventillet paper i hope that it works for this anomaly
I have a toshiba 1370 copier....the repair wrench
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
