20 Most Recent Fostex Mr16hd 16 Track Digital Recorder Questions & Answers
Fostex MR-16 Multitrack Recorder The screen
Hi, try and reset it. it will come back to normal.
Take care.
9/22/2017 5:53:01 PM • Fostex Mr16hd 16... • Answered on Sep 22, 2017
Looking for a manual for a Fostex FD8
Look here: http://www.fostexinternational.com/docs/tech_support/manuals.shtml for the link to download the user manual. For FD-8 there are links to PDF for owner's manual, supplement, and quick guide. I assume the owner's manual is what you seek.
1/17/2015 6:29:56 PM • Fostex Mr16hd 16... • Answered on Jan 17, 2015
How can I record my songs to my tablet or my laptop
The best way is to use the USB output from the Fostex. Connect the USB cable from the Fostex to the USB input of the notebook. A Windows computer should show a USB Audio Device in the device manager. If not, you'll have to get a driver from Fostex and install that. But it should just work, it did in my Vista notebook. Then simply get any number of recording software packages (Windows 8 may have a built-in app). I've used Cool Edit and Reason 4 for recording and editing. You should not record the songs using the notebook's microphone input because (1) the analog noise of a recording generated by the notebook's A-D converter is horrible, and (2) you'll have level and impedance matching problems, even after purchasing something like a pair of Bogen WMT1A line matching transformers. Once you've got it recorded, put it in the cloud and download it onto your tablet. I don't think tablets have USB ports, but maybe yours does.
1/16/2015 9:48:33 PM • Fostex Mr16hd 16... • Answered on Jan 16, 2015
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
11/27/2013 3:11:06 AM • Fostex Mr16hd 16... • Answered on Nov 27, 2013
2answers
I refcently purchased a MR16 Fostex it comes on lights up and shuts down . What is possibly wrong ?
Power supply. Most likely an electrolytic is failing. It may or may not show any signs of it. Other possibilities are bad solder connections, loose wire connections, or possibly a bad MOSFET if it uses a switchmode power supply. Also check the general construction to make sure nothing is shorting internally. Sometimes wires get pinched.
10/27/2012 10:39:22 AM • Fostex Mr16hd 16... • Answered on Oct 27, 2012
For a long time I have been recording on my MR16
Likely you will need an updated driver software compatible with WIn7 for the Fostex. Check the Fostex site for update.
9/10/2011 4:55:40 PM • Fostex Mr16hd 16... • Answered on Sep 10, 2011
3answers
When I turn on the
Hi, the hang up is LIKELY due to the unit NOT getting a ready signal from the internal HD or CD. If you can do a FORMAT on the HD by doing an initialize that would be the first thing to try. These two devices may have a failure... OR the best case is if a cable connector to them has fallen off.
4/20/2011 2:32:31 AM • Fostex Mr16hd 16... • Answered on Apr 20, 2011
When I try to record an audio CD on the internal
I haven't personally used this equipment, but 9 times out 10, a hiss or noise problem is due to damaged or incorrect cables been used.
Check your cables.
Check your gear. If the inputs are TRS (1/4") the make sure your cables are to. This goes for any connection your recorder: balanced cables.
If the inputs are unbalanced, then you would use TS (1/4")
4/3/2011 5:33:31 PM • Fostex Mr16hd 16... • Answered on Apr 03, 2011
I can't find the original manual for this recorder
http://www.fostexinternational.com/docs/tech_support/pdfs/mr16_owners_manual.pdf you'll have to have adobe reader installed in order to open the pdf but it too is free at www.adobe.com
3/18/2011 9:08:02 PM • Fostex Mr16hd 16... • Answered on Mar 18, 2011
I am trying to make a song and I have made the
SING THE FIRST VERSE OF THE SONG, THEN PASTE THE CHORUS, SING THE SECOND VERSE OF THE SONG THEN PASTE THE SECOND COURSE.
12/22/2010 9:19:27 PM • Fostex Mr16hd 16... • Answered on Dec 22, 2010
How can I get an owners manual
From this official link you can get the owners manual (170 pages)
From this official link you can get the supplementary manual (16 pages) for devices without cd drive unit
From this official link you can get the supplementary manual (28 pages) for devices with cd drive unit.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
9/17/2010 1:37:50 PM • Fostex Mr16hd 16... • Answered on Sep 17, 2010
My unit is stuck in "Please Wait" mode.
The hang up is LIKELY due to the unit NOT getting a ready signal from the internal HD or CD.
9/3/2010 3:58:55 PM • Fostex Mr16hd 16... • Answered on Sep 03, 2010
2answers
MR-8. How can I hard reset?
Generally, a hard reset is initiated by pressing a dedicated reset button, or holding a combination of buttons on some mobile devices. Devices may not have a dedicated Reset button, but have the user hold the power button to cut power, which the user can then turn the computer back on.
9/8/2022 8:57:16 PM • Fostex Music • Answered on Sep 08, 2022
Fostex mr 16 digital multitracker, Power button has pushed bin and can not turn recorder on
First, check the fuse. You may need a magnifying glass or an ohmmeter to check it. If the fuse is bad, replace it. If the fuse is OK,or you've replaced it, I'd suggest you take it to a pro audio service center for repair. This sounds like either a major power supply problem, or a shorted component, anywhere in the unit. It may not be cheap, but get a repair estimate so you can decide if it is worth repairing.
11/6/2018 3:50:22 AM • Fostex Music • Answered on Nov 06, 2018
Hi, I own a Fostex VM04 digital mixer.Everything works fine except for some reason the FX just won't work anymore.Any help to fix this would be appreciated.
If you've set it up correctly and FX still don't work, unless you want to keep using it as-is, I'd suggest looking for a used replacement on Ebay etc. They sell for under $70, and although I doubt these can be repaired, it wouldn't be worth it anyway.
11/3/2018 7:10:05 PM • Fostex Music • Answered on Nov 03, 2018
How do I record firSt track on my fostex MR - 8 HD digital motor tracker
User manual for the Fostex MR8HD digital multitracker can be freely downloaded here: www.fostexinternational.com/public/fostex_download.php?f=mr8hd_owners_manual.pdf It is intended to record tracks off of microphones or musical instruments, mix the tracks, and produce WAV or MP3 cuts or audio CD's. Pages 21, 35, and 36 tell you how to make your first recording!
2/9/2015 6:19:29 AM • Fostex Music • Answered on Feb 09, 2015
How do you uninstall and reinstall the drivers on my Fostex MR-8 HD/CD Digital Multitracker?
I don't remember telling you to do this...have you checked out google, or youtube?? There is a vast amount of free info on these sites....it is worth checking out....these digital recorders come with their own operating system...you must be talking about a factory reset....That should be in the owners manual....
11/26/2014 1:42:38 PM • Fostex Music • Answered on Nov 26, 2014
How can I fix my Fostex mixer?
Sound lime a faulty rom have u tried to upload the firmware again
11/26/2014 1:13:03 AM • Fostex Music • Answered on Nov 26, 2014
Fostex Mr16hd 16 Track Digital Recorder Logo
25 questions posted
Top Fostex Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Fostex Music Expert? Answer questions, earn points and help others
View Most Popular
Fostex Music
  • Fostex Music
Most Popular Question
only hear static headphones fostex mr16
  • Music
