20 Most Recent
Husqvarna Lawn Tractor 25 HP 54in Deck Model YTH2454 Questions & Answers
The front wheels toe out
I have the same problem on my YTH2348. I changed both linkage rods and still have the problem. Not sure what is going on. I don't think it is the axle as these are cast iron and would take alot to bend it. Anybody have a clue what I could do to fix it!!!
I was mowing with my 1648 ariens but it only mows on one side
Check for a loose free wheeling blade. If blade is tight try to spin the blade and all should turn. If the blade turns freely without the rest turning, the pulley may be loose and the key sheared off which means you need to pull the cover to do more checking which may require removing the deck. I hope this helps.
Blades will not turn
see you have power and ground going to the clutch connector if no look at the switches and relays if yes look at the wire going into the clutch the break near the coil
I have a husqvarna Yth 2454 lawn tractor and when
What battery did you put in?
Can you provide details of the battery?
if you're using a 4gs or 5gs battery try using a lower one. The amount of voltage the battery releases when you fire up the blades could be causing the fuse to overload and thus blow.
Hope this helps!
We have a JD riding lawn mower, model G110,
Check the Operator Presence Switch located under the seat. If that switch isn't sending a Presence Signal when someone is sitting in the seat it won't allow the blades or Transmission systems work.
My 2 year old Husqvarna riding mower, with the
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
