20 Most Recent Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0 Questions & Answers
2answers
My Grohe kitchen faucet pressure is terrible, I believe I need to replace the screen. Can you help
Not sure if you fixed this yet, but I know that this faucet has a flow control option on it that you might want to adjust.
1/13/2019 1:03:38 AM • Grohe Ladylux... • Answered on Jan 13, 2019
Hot Water pressure is nearly non-existent. Cold
It sounds like you may have an obstruction in the supply valve under the sink. Turn off water to house. Remove supply tube from valve. Unscrew the packing nut. This is the nut where the stem of the valve enters the body of the valve. Remove it and flush the line by having someone turn on the main while you hold a cup or small bucket over the valve to prevent water from going everywhere. Also check to make sure the washer has not come loose. If the washer shot out when you flushed the line, replace it. Be sure to check flow before reinstalling supply line.
9/14/2017 4:26:17 PM • Grohe Ladylux... • Answered on Sep 14, 2017
I have Grohe Ladylux and the flow will arbitrarily switch from stream to spray on its own.
Mine would stick in the spray setting. I soaked the whole head in vinegar to clean it and the problem went away.
2/13/2016 7:22:28 PM • Grohe Ladylux... • Answered on Feb 13, 2016
Clean lime scale from Ladylux cafe pullout
Soak it in white vinegar. It may take longer than stronger chemicals, but you probably have white vinegar on hand.
2/13/2016 7:16:58 PM • Grohe Ladylux... • Answered on Feb 13, 2016
2answers
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
4/7/2015 12:11:35 AM • Grohe Ladylux... • Answered on Apr 07, 2015
2answers
How do I remove grohe water restrictor in kitchen pull out
Unscrew the nozzle from the hose. On the end of the nozzle that screws to the how, you will see the water "restrictor, white ring with 4 little prongs and a black "O" ring in the background. Use a long nose plier and grab one of the prongs and pull out. Screw nozzle back and the water flow will be greatly improved.
1/20/2015 10:44:34 PM • Grohe Ladylux... • Answered on Jan 20, 2015
What do I do about the black rubber coating that is coming off of the handle on my Grohe kitchen faucet?
Contact manufacture , they should replace it
11/21/2014 5:09:08 PM • Grohe Ladylux... • Answered on Nov 21, 2014
How do I set the spring tension on a ladylux kitchen faucet with pullout spray
Personally, I didn't think it was supposed to. I assumed the spring was a form of stress relief for the hose as it nears the pass-through.
9/14/2014 12:22:16 AM • Grohe Ladylux... • Answered on Sep 14, 2014
The faucet is loose on the sink how do i tighten
if you look under the sink at the bottom of the tap there should be a long threaded screw with a nut fastening it to the sink by a curved metal bracket and a rubber washer,( try tightening this.)sometimes the bracket and washer corode if they have then you will have to replace them
8/6/2014 4:01:46 PM • Grohe Ladylux... • Answered on Aug 06, 2014
2answers
How do you remove the spray head from the supply line on a Grohe Ladylux?
Ok not sure what you are asking , but here it goes. If you are wanting to take off the sprayhead simply pull the sprayer out and unscrew. If you want to remove the spray hose from the bottom of the faucet simply grab the red spring loaded connector near the TOP, and pull down spring to release (kind of works like an air hose quick connect). If you want to remove the arch the hose must be removed from the faucet first, then simply jerk up on the arch to remove. When the arch is removed, there is a specialty tool that came with the faucet (which most plumbers keep) to tighten or loosen the faucet. Hope this helps. Luckydog
7/29/2014 11:35:24 PM • Grohe Ladylux... • Answered on Jul 29, 2014
2answers
Ladylux handal can not be
Could not find information for your exact model; however these specifcation which include diagrams of your faucet and installation and maintenance instructions should be useful. See here:
http://www.groheamerica.com/lib/1/tpi/1311703.pdf
Go to Page 5 and look under Maintenance for intruction on how to remove the handle and replace the cartridge.
5/29/2014 9:25:37 PM • Grohe Ladylux... • Answered on May 29, 2014
Need to tighten my ladylux
Grohe has a special tool that is used for installation that comes with the faucet. You have to remove the pullout spray and remove the curved neck of the faucet by pulling out. Insert the tool in the main body and tighten from above. Most plumbers will keep this tool when installing. I don't know if Grohe still uses the same system still today, but they did in the past.
4/5/2014 11:06:48 AM • Grohe Ladylux... • Answered on Apr 05, 2014
Helping a friend tighten up kitchen single handle
handle loose from body of faucet
1/20/2014 9:10:42 PM • Grohe Ladylux... • Answered on Jan 20, 2014
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
5/25/2013 9:28:40 PM • Grohe Ladylux... • Answered on May 25, 2013
2answers
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
3/2/2013 3:50:04 AM • Grohe Ladylux... • Answered on Mar 02, 2013
Where to place 64 689 and 08 565 parts. Ones
IT GOES ON THE INSIDE OF YOUR HANDHELD DOWN BELOW THE HOSE. THE CIRCULAR END GOES CLOSEST TO RHE HOSE AND THE OPEN TRIANGULAR END GOES IN FIRST TOWARDS THE SPRAY END. IT ACTS AS A VACUUM SO FAUCET DOESN'T DRIP. BY THE WAY.THE COLORED ONE IS RESTRICTED AND THE WHITE IS NOT.
2/25/2013 11:59:54 PM • Grohe Ladylux... • Answered on Feb 25, 2013
2answers
Grohe ladylux cafe faucet has low flow eventhough
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
12/9/2012 2:22:19 PM • Grohe Ladylux... • Answered on Dec 09, 2012
Removal from kitchen sink do you unscrew from top ? because horseshoe shaped nut on bottom captures tubes
Tubes should have a some kind of clip or clasp holding them to the faucet hardware, unless they just have a standard supply line with a nut that loosens. Remove the supply lines first & then attempt to remove the main fixture nut. Unfortunately that is always a bit of a hassle, regardless if you have the proper tools. Workspace is tight & tool workspace even tighter. Good luck
7/21/2012 3:16:58 PM • Grohe Ladylux... • Answered on Jul 21, 2012
My new Ladylux appears to have an aerator, but
if its new you should,nt have had to have spare parts fitted,sounds like the tap is faulty,take it back and have it replaced.if you change it and theres still a problem it looks like you might have to change the model
2/16/2012 12:09:54 AM • Grohe Ladylux... • Answered on Feb 16, 2012
The spray feature will not stay on when button is
Sounds very much like a blockage in the sprayer or in the control valve......Blockage in the sprayer head can be a little difficult unless you have the spec sheet that should be in the box with the faucet......however, blockage in the control valve (handle) could be quite a bit more indepth..... perhaps a plumber would be best..... As far as the sprayer...it can be dissassembled to remove blockage whether blockage is in the areator or in the hose itself....still a fair to medium job.....Plumbers often use pipe compound to seal threads and some use a teflon thread tape that sometimes gets into the small openings and cause blockage......with the weaken pressure it could very likely cause the button to work improperly.......hope this helps.....
9/1/2011 11:03:42 PM • Grohe Ladylux... • Answered on Sep 01, 2011
Grohe Ladylux Cafe Faucet with PullOut Spray in Stainless Steel 33755KD0 Logo
105 questions posted
Top Grohe Plumbing Experts
john h
vince
Paul Carew
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Grohe Plumbing
  • Grohe Plumbing
Most Popular Question
remove spray head from supply line grohe
  • Plumbing
