20 Most Recent
Master Heaters Master Airbrush Model G75 Airbrushing System with AirBrushDepot TC20 Tankless Air Compressor Questions & Answers
My daughter bought a master airbrush spray tanning
I got the exact same kit as a Christmas gift (I am a cake decorator). I have asked the supplier how to fix this problem, but they only told me to google airbrush videos. I'm not sure how to connect all the hoses to the compressor and the external paint cup. Been struggling for weeks to find info online. I also have a G34 and that works fine (but it only holds a miniscule amount of paint). Good luck, hope you manage to get an answer.
How do I connect a badger airbrush hose to a Airbrush Depot TC20T compressor?
Airbrush Depot compressor should be a 1.4NPT which is the most common- Badger makes an adapter for this size to their hose fitting. That fitting should be available from many sources. Badger did/does use a couple of sizes so make sure you know which model of brush you have.http://badgerairbrush.com/Acessories_4.asp is the piece.it is at the bottom of the page.If nothing else, it should be available through Walthers http://www.walthers.com
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes.
Read your user manual for more information.
