20 Most Recent
Bobcat Equipment Skid Steer Flatbed Tractor Trailer Questions & Answers
763 bobcat hdy and travel locked up when starting
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwivi_HHuK6DAxVCC3kGHUEmCY0QFnoECBYQAQ&url=https%3A%2F%2Fwww.skidsteerforum.com%2Fthreads%2F763-g-bobcat-still-locking-up.92889%2F&usg=AOvVaw1iO8ODs5gqdyL4oELS8yf3&opi=89978449
Bobcat t650 has m1732 code
ONLY: If your Bobcat T650 is displaying the M1732 code, it indicates a problem with the fuel pressure sensor circuit. This could be caused by a faulty sensor, damaged wiring, or a problem with the engine control module (ECM).
To start troubleshooting this issue, you should first inspect the wiring and connections for any signs of damage or corrosion. If everything appears to be in good condition, you can test the fuel pressure sensor using a multimeter to check for proper resistance values. If the sensor is found to be faulty, it will need to be replaced.
If the sensor and wiring are both in good condition, the issue may lie with the ECM. In this case, it is recommended that you take your Bobcat T650 to a qualified technician who can diagnose and repair the problem.
How to put distributor in a wisconsin v-4 fan cool engine?
Go to number one piston and remove plug. Put finger over hole while tapping starter. When pressure(air) comes out of cylinder put piston to the top. Put distributor into position with the rotor pointing to number one . Re install spark plug and hook up all four wires. 1-4-2-3? not sure of firing order. Start and run engine.
Adjust distributor to highest idle RPM, w/o kickback when starting.
Gauge reads full all the time
sending unit inside tank may be bad or stuck.remove the wire on the top center of sending unit and remove sending unit.make sure it moves free.you can also test it outside the tank by hooking up wires same lacations and move sending unit float up and down slow.
