20 Most Recent
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Questions & Answers
17 hp kohler starving for fuel.
runs for too long to be a fuel problem
more like an overheating electrical component or voltage falling too low to run the ignition system
Toro 52" deck with 19hp kawasaki engine runs fine
Could also be a carburetor issue, remove air filter and make sure that its not clogged, even try running it for a short time under the same load. If problem persist tske it to rdpair shop bc there are several other issues it could
I have a Kohler Courage 19 on a Troy built lawn
sounds like you are on the right track, I would replace the needle and seat and also check the roll over solenoid that is on bottum of float bowl, some times they go bad and do that. and they have also had issues with needle and seat not sealing,. some people have put shut off valves on their line and turn it off when not using hope this helps you, don't forget the thumbs up!
Why won't my rider move and keep running?
Something is jammed in the drive and when you put the mower in gear the motor stalls. U need to locate the source of the problem - once you do that all will be copacetic.
Toro zero turn will not turn over
How long has it been since last running? Are all the safety switches activated? Handles pushed back all the way? Sitting on seat (i presume) ? Parking brake engaged? I would also check the oil. What does the oil look like?
