20 Most Recent
Olympus DM-20 Digital Voice Recorder Questions & Answers
How do I Change from default language back to English?
To reset the settings back to English:
1. Set the DM-20 to Voice mode using the blue switch on the back voice recorder.
2. Remove the DM-20 from Hold using the gray switch on the back of the voice recorder.
3. Press and hold the DISPLAY/MENU button on the front of the DM-20 for at least 3 seconds. The menu list is displayed.
4. Click the REWIND button six times to highlight the Format menu item.
5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
6. Click the REWIND button once to highlight Start.
7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
8. Click the REWIND button once to highlight the Start menu item to continue with the format.
9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
Olympus DM-20 erase lock is on, how to undo it?
The voice recorder is in read only status - you will need to format the device to remove the lock (read only). Go to menu - to submenu and then run the format option. make sure all files have been downloaded as once device is formatted all files will be permanently deleted
Unlocking the DM-20 digital recorder
Unfortunately if you are unable to unlock using the Lock Unlock feature. You will need to format the device. This will erase all data and unlock the machine to be able to record to it again.
