20 Most Recent
Timex Atlantis 100 77517 Wrist Watch Questions & Answers
How do I get the alarm off
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please .
Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
Battery replacement Timex T2H381
This will depend on the back of the watch. Totally smooth watch back is usually a push fit. Using a small precision screwdriver you Gently lever around the back plate until it 'Pops' off. the battery should hook out by CAREFULLY using the screwdriver you used to remove the back plate. *Note* check which way up the battery is fitted BEFORE you remove it. The back plate should just push on and should quietly click when seated correctly.
Some back plates are 'screw on'. You can usually spot these by the dimples or notches on the back plate where the removal tool fits.
