20 Most Recent Onkyo TX-DS575 Receiver Questions & Answers
Settings
As mentioned, I have got to the bottom of this without Onkyo's help. I replaced the offending component, which is a 5.5V 0.1F backup capacitor. This is mounted on the front PCB, just below the right hand side of the display. It is a right pain to get to. Here briefly is what to do:
1: Unplug (really important!), remove top cover.
2: Undo three screws underneath front panel edge, pull off volume and tone knobs, and gently pull off metal front panel from the bottom, which is held with sticky tape inside.
3: Undo five screws from plastic front panel and free it. You will now have limited access to the front panel PCB and audio processor PCB.
4: Cut a few black cable ties as required to gain better access to front PCBs, and unplug ribbon cable from right hand side. It may be helpful to undo the nut and so release the volume control encoder.
5: Still struggling with poor access, release the standoffs from the audio processor PCB and unplug its ribbon cable. You have to remove the audio processor PCB in order to get to the screws under it. You may want to remove the PCB for holding the mains switch.
6: Now with some kind of access to the whole of the front panel PCB, undo 10,000 screws which secure it to the black plastic front panel.
7: Now with limited access to the front side of the front panel PCB, locate the capacitor, towards the right hand side of the display, just beneath it. Note the polarity; the negative terminal goes to the left/top pcb land, positive to the bottom/right. Desolder and replace this component. HINT: Make life easier for next time and mount the new part on the REAR of the PCB, so now negative will be down. Care with polarity!
8: Reassemble carefully. Make sure that the volume control encoder metal clasps are tight as they come apart easily. Fit new cable ties in original locations (important to prevent hum pickup).
The parts you will require then are about 6 nylon cable ties, and a 0.1F 5.5V capacitor. I had to make do with a 0.047F part because it was all I had to hand and I didn't want the machine in bits while I ordered one. Many of these components today are radial PCB mounting, which are not an ideal fit but could be used at a push. If you can get a vertically mounted one, that would be better. The nearest I can readily find is from RS Components item 377-350 (Panasonic EECS0HD104V), and the leads on this could doubtless be re-jigged to fit.
9/30/2018 9:37:47 PM • Onkyo TX-DS575... • Answered on Sep 30, 2018
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
9/27/2017 6:34:31 PM • Onkyo TX-DS575... • Answered on Sep 27, 2017
When I connect the sirius radio to the docking
Hello, I am sorry about your issue. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
7/11/2017 4:25:13 PM • Onkyo TX-DS575... • Answered on Jul 11, 2017
2answers
Resoldering of Q710
Hello, I am sorry about your issue. I suggest having the receiver serviced. Thank you, Onkyo USA
5/11/2017 5:08:29 PM • Onkyo TX-DS575... • Answered on May 11, 2017
3answers
I have a TX-DS575 receiver
Replace the IR receiver diode on the front panel. Try HERO HIM602H from farnell.com, i used that one for my TX-DS 777. (i guess 575 using same stuff)
5/10/2016 10:55:33 AM • Onkyo TX-DS575... • Answered on May 10, 2016
Receiver shuts off when loud content comes on TV
Hello Jerry, This means that the unit is going into protection mode. The unit will only go into protection mode for 2 reasons. The first reason would be if there is a short within the unit itself. The second reason would be if one of the speaker connections is causing a short. To isolate which of the two is the issue, you would first turn the unit off and unplug all of the speakers. Turn the unit back on with no speakers connected and raise the volume up. If the unit turns off with no speakers connected then we know that the issue is internal and would have to go in for repair. If the unit stays on, that will tell us that one or more of the speaker connections was causing the issue. If that is the case I would check all of your speaker connections and possibly start with fresh copper connections. Thanks, FJD
4/1/2016 5:12:26 PM • Onkyo TX-DS575... • Answered on Apr 01, 2016
Hooked to surround sound, two front speakers, 4 wall speakers, 1 sub woofer. Restart unit and reduce volume unit is OK but normal talking is too low.
Voice tracks are usually routed to the center channel. You don't mention having a center channel speaker hooked up. If this is the case, then you need to go into the receivers setup menu and set it for no center. This will reroute the voice tracks to your front speakers.
2/26/2016 11:59:25 AM • Onkyo TX-DS575... • Answered on Feb 26, 2016
3answers
Onkyo TX-DS575X, remote intermittend malfunction
You have to raplace IR sensor PIC-26043TE2 or similar and should help.
1/10/2015 1:31:45 AM • Onkyo TX-DS575... • Answered on Jan 10, 2015
How do connect surround sound receiver to my tv
use the optical port (toslink cable needed)little square with flap will be lit red or use rca cables red and white audio out fron tv to any port on reciver(aux,cd,dvd,ect) the reciver will have to be turned to this for the surrond to be heard
9/8/2014 5:18:13 PM • Onkyo TX-DS575... • Answered on Sep 08, 2014
0answers
Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
4/7/2014 4:58:21 PM • Onkyo TX-DS575... • Answered on Apr 07, 2014
Right front channal buzzes
Only the one channel buzzes? Did you check the cable of the speaker is it properly rolled?
2/26/2014 4:24:44 PM • Onkyo TX-DS575... • Answered on Feb 26, 2014
I have lost the remote control of my Onkyo TX-DS575 AV reciever/DTS Amp and cannot find one in the market. I have used a universal remote which had a couple of Onkyo codes with it but it doesn't work.
Amazon.com, MyRemoteControls.com, and Remotes.com all sell a replacement remote for the TX-DS575. I have also seen the Onkyo TS-DS575 receiver with remote listed on eBay for as low as $35. Keep looking; the remotes are out there.
1/22/2014 3:54:43 PM • Onkyo TX-DS575... • Answered on Jan 22, 2014
No sound
I have a Onkyo receiver, I had the same problem. I took it to a repair shop and they found there was a poorly soldered connection on a circuit board. They re-soldered it correctly and it works fine now. I would not have been able to find this myself. Just sharing my experience, your problem may or may not be related. You may need to take this to a repair shop, if it is really circuit board related like mine was, it is not something the average person has the training to find and repair.
12/13/2013 12:45:46 AM • Onkyo TX-DS575... • Answered on Dec 13, 2013
Re EQ function without remote controller
Purchase a customizable universal remote or a Logitech Harmony remote.
11/16/2013 6:26:48 PM • Onkyo TX-DS575... • Answered on Nov 16, 2013
Onkyo TX-DS575 Receiver Logo
167 questions posted
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
right front channal buzzes
  • Audio Players & Recorders
