20 Most Recent
Fastway Adjustable Linkage Guard Trail Black Questions & Answers
How to adjust the column shifter on a 1951 chevy deluxe car
Hello Jeff Poe,
Assuming you are talking about the MANUAL TRANSMISSION... simply because of the "FASTWAY" product you are posted under... (appears to be the old "three on the tree") column shifter.
And
Assuming ALL your
shift bushings are new & firm
You can have an assistant find and hold the
neutral
(fully disengaged... but middle of the
"H" position)
In the car: Have your assistant select the first & reverse positons. Under the vehicle: Carefully observe the throw in each direction.
Underneath at the transmission shift lever: Pull the cotter-pin and remove the washer from 1st (1st & reverse) gear shift lever.
Manually operate the shift lever to feel the exact center of its disengaged position (after assuring your assistant is holding the shift lever in the middle of the lever throw... adjust the lever to lengthen or shorten to precisely match that centered position.
If the vehicle has been used... very little adjustment should be required. Place the pivot pin, restore the washer and fit a new cotter-pin.
Repeat the process for the 2nd (2nd & 3rd) gear shift lever.
Hope this helps.
https://en.wikipedia.org/wiki/Powerglide
Manual transmission
8/1/2016 12:53:42 PM •
Fastway...
Answered
on Aug 01, 2016
Well just wondering what i am
Ok, go to your bathroom, look at the mirror and if you see a face there, probably you are a human.
4/24/2015 2:42:15 AM •
Soccer
Answered
on Apr 24, 2015
: What equipment do I need to buy so that my son is prepared for his first day of soccer?
One of the reasons
soccer is a great sport is because it requires so little gear. Like in any sport, you should make sure your
son is equipped with a large water
bottle and that he wears shorts and a t-shirt that are breathable. If he is just starting out, he doesn't need
to have cleats yet. It's better for
beginners to learn to play without cleats so that they don't injure themselves
or their teammates. The most important
piece of equipment is shin guards that are fitted to the length of your sons
lower leg.
1/7/2015 10:54:43 AM •
Soccer
Answered
on Jan 07, 2015
What is offside?
Offside is a very controversial offense in soccer. A player will receive a penalty if caught by
a ref and it can make goals considered invalid.
It is when the offender makes a shot for the goal when none of the other
teams defenders are next to or in front of him.
For a more comprehensive explanation of offside, check out this link:
http://onthepitch.org/2006/02/28/a-offsides-primer-for-parents/
7/10/2014 4:04:57 AM •
Soccer
Answered
on Jul 10, 2014
What is advantage and why is it considered so unfair?
Advantage is considered
a serious problem in soccer. Advantage
is when a team gains control of a ball by doing something illegal or fouling
the other team. It is considered dishonest
playing and is not accepted in most soccer leagues.
2/6/2013 1:45:43 PM •
Soccer
Answered
on Feb 06, 2013
How come soccer balls have those black panels?
The black panels allow players to understand the spin the
ball is taking. This allows their moves
to be more accurate because it helps to determine the direction and velocity of
the ball.
2/6/2013 1:43:55 PM •
Soccer
Answered
on Feb 06, 2013
What are soccer balls made of and how big are they?
Soccer balls are also
referred to as a #5 ball. The ball
itself must have a circumference between 27 and 28 inches. When filled with air, it should weigh between
14 and 16 ounces. They are made of
leather or a like material.
1/14/2013 12:10:44 PM •
Soccer
Answered
on Jan 14, 2013
