20 Most Recent Vizio P2 42 in. HD-Ready Plasma Television Questions & Answers
3answers
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
3/29/2022 9:54:29 PM • Vizio P2 42 in.... • Answered on Mar 29, 2022
I have a Vizio P42HDTV10A TV that no longer has a
Chances are something in the power supply board failed and that was the pop you heard, a new board should get ti going again
2/21/2018 2:25:33 PM • Vizio P2 42 in.... • Answered on Feb 21, 2018
42" Vizio will not turn on.
Sounds like a fuse and/or Circuit board components have failed. Would not suggest atempting repair unless you are familiar with electronics and the hazards associated with repairing such equipment. Can do damage to yourself or further damage to the equipment.
10/23/2017 11:54:36 PM • Vizio P2 42 in.... • Answered on Oct 23, 2017
4answers
Vizio 42" LCD Screen (VW42L FHDTV10A) Screen is cracked
i have a 42" cracked vizio screen, where can i find a replacement screen?
9/26/2017 10:46:24 PM • Vizio P2 42 in.... • Answered on Sep 26, 2017
4answers
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
9/15/2017 11:54:08 AM • Vizio P2 42 in.... • Answered on Sep 15, 2017
Visio Plasma TV, VP42 HDTV, had no standby LED,
You have a shorted circuit board in there somewhere, fuse pop for a reason.
6/24/2017 5:05:12 PM • Vizio P2 42 in.... • Answered on Jun 24, 2017
NO AUDIO, VIDEO, AND BLACK SCREEN
Appear the high voltage don't is generated, may be the power supply internal, normaly is caused by failure the current-down and overload.Review the voltages of the main source.
12/14/2016 7:32:21 AM • Vizio P2 42 in.... • Answered on Dec 14, 2016
2007 60 inch vizio plasma hdtv model vm60p screen went half dark pitcher half blurey happend all at ounce im not sure what is wrong not very good with plasmas
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
8/24/2016 2:11:29 PM • Vizio P2 42 in.... • Answered on Aug 24, 2016
How can I access netflix I have wifi
If you have your WiFi set up on your device all you need to do is open your browser and go to http://www.netflix.com/ and sign up for an account if you don't already have one :)
4/24/2016 4:44:00 PM • Vizio P2 42 in.... • Answered on Apr 24, 2016
4answers
Vizio tv
i used the goldstar codes on my vizio tv and it worked
heres a list of codes
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, 172, 196
the code 004 worked on my 32' Vizio HDTV, for the Jumbo Universal Remote
3/2/2016 6:41:29 AM • Vizio P2 42 in.... • Answered on Mar 02, 2016
How do I connect my vizio TV to WiFi without remote
Without a remote control, you can't. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
1/6/2016 3:59:29 AM • Vizio P2 42 in.... • Answered on Jan 06, 2016
How do you turn the sound speakers back on if you don't have the remote?
If you go to you tube and type in "how do I turn on the sound without a remote on the VIZIO P2, 42inch tv .there are 4 or 5 videos info about retuning another remote for you set give it a look and see if it solves you problem .
12/21/2015 12:10:52 AM • Vizio P2 42 in.... • Answered on Dec 21, 2015
Vizio P2 42 in. HD-Ready Plasma Television Logo
613 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
need get hooked up
  • Televison & Video
