20 Most Recent Casio FX82ES Scientific Calculator Questions & Answers
Can i solve matrices in casio fx_82ES plus?
Apparently you can
8/8/2023 4:02:32 AM • Casio FX82ES... • Answered on Aug 08, 2023
2answers
How can i enter a matrix in fx-82ES?
You cannot do matrices with this calculator. Use an FX991 ES, or FX115 ES.
7/9/2019 5:14:13 PM • Casio FX82ES... • Answered on Jul 09, 2019
Solve complex
Calculator cannot handle complex numbers.
5/22/2018 12:53:07 AM • Casio FX82ES... • Answered on May 22, 2018
How do i find cotan on casio fx82es plus
To get the cotangent, you use cot(x)=1/tan(x).
4/8/2018 1:57:01 AM • Casio FX82ES... • Answered on Apr 08, 2018
0answers
Dear EKse
Be the first to answer 1/7/2018 2:00:04 PM • Casio FX82ES... • Posted on Jan 07, 2018Be the first to answer
3answers
When i press MODE there is no choice 6 [Matrix] and i want to multiple matrices there are only 3 choices 1: COMP, 2:STAT, 3: TABLE.
You are confusing this calculator with one of its more sophisticated brothers (FX 115 ES Plus or FX991ES plus). The 82 ES plus has only three modes.
12/31/2015 7:35:45 AM • Casio FX82ES... • Answered on Dec 31, 2015
How to bring answers in decimels in calculator fxd8esplus
8/27/2014 2:58:59 PM • Casio FX82ES... • Answered on Aug 27, 2014
How can i factory reset
Press the [S<=>D] key to convert from fraction to decimal and back. Any information you need is in the manual.
8/14/2014 10:55:26 PM • Casio FX82ES... • Answered on Aug 14, 2014
I want 100000 to appear as100,000
I am afraid there is a misunderstanding. The sequence you describe changes the decimal marker from a dot to a comma. It does not insert a thousands separator. a6404402-bcb5-4397-82a1-22e55e334b4b.png
5/16/2014 8:45:04 AM • Casio FX82ES... • Answered on May 16, 2014
Y>x^2-4x+3
You need to draw the curve y= x^2-4x+ 3. It is a parabola. The equality (=) is verified by all points on the curve. The curve divides the whole plane in two regions. In one region y will be less than x^2-4x+3. In the other regions y will be larger than x^2-4x+3 The regions are the interior of the parabola and its exterior. To find out the region where your inequality is verified you proceed as follow.
  1. Look at the graph and choose the coordinates of one point. Select integer values (BTW the point (0,0) is usually a good candidate) and write y ? x^2-4x+3 where the ? stands for the inequality sign you will have to insert to make the relation correct.
  2. Take x=0, and y=0 and substitute in y ? x^2-4x+3
  3. 0 ? (0^2)-4*(0)+3.
  4. Clearly the ? stands for < because 0 <3.
  5. So at all the points in the region where (0,0) is located the condition y< x^2-4x+3 is TRUE.
In the other region y < x^2-4x+3, is FALSE and that second region (the one that does not contain the origin (0,0) is the one you need to find. It represents your solution set. Note that the origin (0,0) does not lie in the solution set region wereup0ohrv3gaaaabjru5erkjggg==
3/4/2014 2:47:48 AM • Casio FX82ES... • Answered on Mar 04, 2014
Open screws
If you want to open it, just undo the screws on the back, there is no secret incantation that one can say to make thing easier than that. Open it at your own risk.
1/29/2014 2:54:28 AM • Casio FX82ES... • Answered on Jan 29, 2014
Area of traingle with tree
All triangles have three sides. There are two main formulas that do not call on trigonometric ratios. The classic one:
  • 1. You need the length of a base and it corresponding height (the length of the segment perpendicular to that base and passing through the vertex (summit) opposite to that base. Area=(1/2) * (measure of the base)*(measure of the height). The base and height must be expressed in the same unit.
Heron's Formula if you have the length of the three sides. Let those measures be a, b, and c.
  • Calculate the semi-perimeter p with p=(1/2)(a+b+c)
  • Area=Square root of (p*(p-a)*(p-b)*(p-c))
  • a, b, and c must be expressed in the same unit.
1/18/2014 3:14:08 PM • Casio FX82ES... • Answered on Jan 18, 2014
My calculator is clear all
Press [SHIFT][9] (CLR). Then select 3:All. Everything will be reset to default. 613f1de9-11ed-4da9-9f39-afca143a3f84.png To setup press [SHIFT][MODE](Setup) and change the settings you want. 8b62aa8c-cf7f-4d70-baa0-289a2221ac0f.png 1: to use MathIO display mode; 2: to use the LineIO, 3: 4: 5: to change the angle unit. 6:Fix to set Fixed number of decimals, 7:SCI scientific notation display, 8: Norm for Normal display mode. (read your manual for that). By pressing the Arrow Down button you get other setup choices. 1: to display mixed numbers, 2: for improper fractions, 3: Stat; 4: to chose the dot or the comma as a decimal marker. 5: to adjust contrast of the screen. ec9a5bea-eaa9-4fa1-94ac-832c9c8ad63e.png
1/18/2014 3:00:10 PM • Casio FX82ES... • Answered on Jan 18, 2014
My casio fx-es is not
That covers a lot of possibilities. Sorry I can't help if you do not give details.
1/18/2014 2:44:40 PM • Casio FX82ES... • Answered on Jan 18, 2014
How to solve r in linear regretion
Find the formula for the correlation coefficient and use the calculator to calculate it. You can also use the calculator to do statistics. It has some keys to retrieve the statistical values calculated. You will find r among them. Please do read your manual to learn how to do statistics.
1/18/2014 2:41:57 PM • Casio FX82ES... • Answered on Jan 18, 2014
Prime factorization
Do you have a question? Find the prime factors of a natural number. This calculator does not have a utility/feature that does that for you. However you can use it to help you carry out the sequence of divisions you have to do, while you keep count on how many times you divided by 2, by 3, by 5,7, etc.
1/18/2014 2:33:51 PM • Casio FX82ES... • Answered on Jan 18, 2014
Remainder fractions
Hello.You would be looking for a function called 'MOD' which returns a remainder. so 7 MOD 6 = "1".If your calculator does not have the MOD function... then you can do it by 7 divide by 6 = 1.16666... then take the fractional portion 0.16666 and multiple by your divisor, 0.166666 x 6 = "1". So you can easily calculate it.Hope this helpsJeff
11/4/2013 10:33:31 PM • Casio FX82ES... • Answered on Nov 04, 2013
I have a Casio fx 82 MS and when i do calculations
Reset your calculator. If you choose an Exponential display format (Scientific, Engineering, Normal1, Normal2) select more decimal digits. Your current setting seems to display no decimal digits.
10/8/2013 4:22:50 PM • Casio FX82ES... • Answered on Oct 08, 2013
Casio FX82ES Scientific Calculator Logo
44 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
change back
  • Office Equipment & Supplies
