20 Most Recent Magimix 3100 1057 Cups Food Processor Questions & Answers
Magimix compact 3100. Are there instructions on how to replace the button on it please?
Question edited for clarity. Question moved from Cars and Trucks category. Unfortunately not much! There should be screws on the base, they are probably hidden under the feet. That should split the case. https://www.google.com/search?q=Magimix+compact+3100.+replace+the+button ..
12/7/2023 5:25:28 PM • Magimix 3100... • Answered on Dec 07, 2023
tip
How to clean the handle of a Magimix
The handle of a magi mix cannot be removed. This is how you can clean the muck out of the handle. There are two openings at the top of the handle. One next to the bowl and the other is at the top of the handle grip. Pour dishwashing liquid (as much as possible) into the two openings. You will see it flowing into the handle. Then you will need a 'K'archer (or similar) water blaster. Direct the jet into the two openings. This should be done with the jet almost in contact with the handle to achieve maximum pressure. The dirt will start to come out. Repeat this cleaning operation with the dishwashing liquid and water jet (perhaps 5 times) until the handle interior is clean. There are 4 small drain holes on the sides of the handle into which dish washing liquid can be poured and jetted out. I know this method works, as I have done it successfully on my wife's Magimix! Good luck! Des Pollard Cape Town, South Africa. 12 March 2019
tip
The handle of a magi mix cannot be removed. This how you can clean the muck out of the handle. There are two openings at the top of the handle. One next to the bowl and the other is at the top of the handle grip. Pour dishwashing liquid (as much as possible) into the two openings. You will see it flowing into the handle. Then you will need a 'K'archer (or similar) water blaster. Direct the jet into the two openings. This should be done with the jet almost in contact with the handle to achieve maximum pressure. The dirt will start to come out. Repeat this cleaning operation with the dishwashing liquid and water jet (perhaps 5 times) until the handle interior is clean. There are 4 small drain holes on the sides of the handle into which dish washing liquid can be poured and jetted out. I know this method works, as I have done it successfully on my wife's Magimix! Good luck! Des Pollard Cape Town, South Africa. 12 March 2019
My MagiMix food processor is running but there is not much power and the spindle is turning very slowly. Does anyone have any repair suggestions?
It could be two things. The carbon brushes to the motor need replacing. or The motor capacitor is failing. If your motor is running Slow or just Humming and not going round, it could be the capacitor, this can be caused by running in a damp atmosphere or continuous use ie commercial.
Magimix Capacitor 60UF 50UF - Motor Running slow
Magimix Spares https://www.magimix-spares.co.uk > product
Why do the blades spin much slower than they used to?
iFixit https://www.ifixit.com > Answers > View > Why+do+t... Oct 21, 2016 - Sounds like the connection between the blades & the motor is worn. Separate the driven blades part from the driving motor part. Look at both the ... 2 answers · Top answer: If your machine is not jammed by food, the most likely cause of your problem is ...
Magimix Food Processor - Can I fix it?
DIYnot https://www.diynot.com > ... > How to... > Appliances Jan 1, 2021 - Now the blades are spinning very slowly and cutting through a thick carrot stops it spinning completely. And after only maybe 30 seconds of . ..
1/23/2024 3:14:30 AM • Magimix Food... • Answered on Jan 23, 2024
Finding the right key to unscrew the base of my Magimix Cuisine 4200
You mean the Security Screws? You need a set of bits or drivers. https://www.google.com/search?q=security+screw+bits ..
3/23/2023 5:15:16 PM • Magimix Food... • Answered on Mar 23, 2023
Hi my magimix 320xl won’t turn on the Handel clicks in ok so I’m not sure what the problem is it’s only been used a couple of times hope you can help me thank you Christine
If your Magimix food processor won't turn on despite the handle clicking in, there may be a problem with the power supply or the motor of the device. Here are a few troubleshooting steps you can try:
  1. Check that the power cord is securely plugged into an outlet and the processor's base.
  2. Make sure the outlet is working by plugging in another device.
  3. If the outlet is fine, then try plugging the Magimix into a different outlet.
  4. If the device still doesn't turn on, it's possible that the motor has overheated. Allow the device to cool down for a few hours and try turning it on again.
  5. If none of these steps work, you may need to contact the manufacturer or a repair technician for further assistance.
It's also worth noting that the Magimix 3200XL comes with a 30-year motor guarantee, so if the motor is the problem and the device is still under warranty, you may be eligible for a replacement.
2/24/2023 6:19:11 PM • Magimix Food... • Answered on Feb 24, 2023
I would like to purchase a new bowl and large blade for the Magimix 5100
fixya doesnt sell products ---try manufacturer --small appliance repair shop--online search
2/3/2023 11:48:52 AM • Magimix Food... • Answered on Feb 03, 2023
2answers
Why isn't the pulse button working?
12/6/2022 3:48:26 AM • Magimix Food... • Answered on Dec 06, 2022
Magimix 5000 cuisine systeme. I can't get the lid off. Do you know how to unlock it please?
Hi, If you reach the top of the lid, there might be engraved instructions on how to remote the lid. Sometimes you just need to twist it counterclockwise before pulling out the lid. If you still have issues after doing these things, please refer to the product manual via the table of contents to see instructions for removing the lid. Thank you.
6/5/2022 5:57:16 PM • Magimix Food... • Answered on Jun 05, 2022
How do I remove the blade unit from Magimix cuisine 5100?
Firstly, press the STOP button. Then turn the lid in a clockwise direction and lift-off. Carefully remove the blade and inner bowl/bowls (depending on what combination you are using). Finally turn the main bowl clockwise to unlock it from the motor unit and lift off.
1/10/2022 12:24:06 AM • Magimix Food... • Answered on Jan 10, 2022
2answers
How do you open the magimix food processor to see what is wrong?
Screws on the base. Often hidden under plugs or feet.
11/9/2021 2:48:10 PM • Magimix Food... • Answered on Nov 09, 2021
2answers
What tool is needed to undo the four screws below the Magimix. I need to remove and clean the buttons which won't depress and sticky due to an overflow of mixture. Thank you
you did not described the screw or model of your machine, most of them use "secure" screw system of various shape, you need to check what shape is your particular screw and then go to closest hardware store and buy set containing that particular screw, magimix use mostly torx screws, but you need to check as this vary from country to country... just to make our life more difficult...
11/9/2021 2:27:40 PM • Magimix Food... • Answered on Nov 09, 2021
I have a magimix 2800. I have 3 cutting discs but what else do I need in order to be able to use these in the machine?
You need the spindle that goes onto the bottom drive and the slicing and grating discs go on top. All you parts are here https://www.google.com/search?q=magimix+2800s+spare+parts ..
9/9/2021 8:48:50 PM • Magimix Food... • Answered on Sep 09, 2021
Magimix 3100 1057 Cups Food Processor Logo
Popular Tags
12 questions posted
Top Magimix Food Processors Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Magimix Food Processors
Most Popular Question
instructions replace button magimix
  • Food Processors
