20 Most Recent
Quasar SP-3233 TV Questions & Answers
Picture too dark
mkbowen,
whats the brand name of your TV?
also try this, facing the front of your screen. locate a button indicating " menu" and click it.
once the menu button been activated there would be a display box indicating "AUDIO" "VIDEO" "TUNNING" or in some cases the screen will indicate one by one setting every time you press the "menu" button. If you'll able to find a display indicating "video" higlight the said icon and navigate throught it until you see the control for brightness. you can navigate the icon by pressing +/- channel button and to change the value of selected item you need to press +/- volume button of the screen.
cheers ,
mark
Some buttons on remote don't work.
Your remote need cleaning. There are improper contacts between the touch pad to internal carbon tracks. You have to open the remote control to do this. Visit this site named 'Electro-help' for details. Check
this link, and select the site. It have details about how to clean a remote control. You may also get details about the availability electronic components too, from associated ads. Pull up older posts there.
32" TV fell over onto carpeted floor and won't
It's probably a write-off. The circuit board inside has been cracked so that some of the copper traces that connect parts have broken. This commonly happens around the area of the horizontal output transformer, which is heavy. The shock of the fall causes the transformer to bounce and breaks the board. Other areas too may have been damaged because of flexing. And worst, the picture tube can be damaged in a fall, so it either doesn't work at all or shows permanently distorted colors.
It's tough to find anyone willing to repair a set that's fallen. Many circuit board tracks are very narrow and hard to repair. Then it's difficult to know if all the damage has been found and repaired, so even if the set starts working a technician doesn't know if something else won't go wrong. And then there's that bad tube possibility; no technician likes to spend lots of time fixing a broken board only to find the set then needs a new tube. Trust me, this has happened to me several times during my career in TV shops.
Your best bet is to use this as an excuse to buy a new LCD or plasma TV. 40-inch models, a good size match for a 32-inch CRT (tube) model, are reasonably priced.
Lost the manual. How do I turn on/off the
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers and Driver
downloads
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
Quasar tv model no sp3233b
how
Size: Width - 70cm/28in; Height - 66cm/26.5in; Depth - 58cm/23in. Weight - 33kg/110lb . With the packing all these dimensions will grow noticeably.
The tube of the tv is fragile so the entire tv must be packed on thick polystyrene sheets (like the ones the tv originally came) and a sturdy cardboard box - packing foam will not do and taped bubble-rap will be bulky it you put enough to do the job.
Tv is locked how to unlock no code
Hi mark
To answer your question;
Try to hold the "action" and "power" buttons at the same time for more than 10 secs.
Another one is:If you can get into the menu under "game guard" there might be a lock code , try 333
This works on panasonic tv of the same model, but then quasar is panasonic.
Don`t forget to rate this answer if its helpful
Where is the action button
If you do not have a remote control for the television, you can purchase a replacement remote which has similar functions and can be used to set / operate the television. You can purchase a replacement remote from
here.
Also let us know which functions you are trying to access from the TV menu buttons (like tuning the television, adjusting the picture/sound)
Thanks for using FixYa.
Code
im a tv expert and we have always these problemes, what you should do is contact your cable or sat provider and tell them your problem and ask if they can reset you acount or code im sure they can help or bring a tv technician and they could fin dout the probleme CONTACT ME AT
[email protected] and il see if i can give you more information
1) I own a Quasar
If the screen is dark, then the brightness and contrast adjustment must be poor. Use the MENU key (in the TV or the Remote, either) adjust the brightness and contrast as per your viewing convenience. Service manual for this model is not in my knowledge and you should not try to repair or troubleshoot it by yourself without proper knowledge of the circuit workings inside.
Sony 20" wega
if your tv give you that color or keeps fliking your tv screen might be crack or even the tv bolbe is burned get it checked out at a tv store
Tv code
im sorry but to let you know diamond vision tv is a private tv company that why they are not listed in any universal remote codes because they work for them self and they think that people will stop buying there remotes and so they decide not to programe any codes for other remotes
Removing playing cards from inside of a TV
Hi there!
You can certainly do this yourself. However take care not to break the tube neck when doing so and unplug from mains before you start. All TV'S can be opened by unscrewing the screws around the edge of the frame first. Then on the back panel you should find more screws that holds the AV sockets panel onto the cover. Once all screws had been removed, carefully pull the cover backwards making sure that you don't drop it before the tube neck is completely clear from the cover. Remove the playing cards and reassemble the same way, making sure that all sides are firmly slotted before replacing the screws again. You are correct in quoting "Fire Hazard". It is indeed. Regards and good luck, JUS004
Quasar SP-3233 TV
well it's not a wide screen tv show it won't really matter but if it is H/D you will find a red/green/blue connection in the back for picture and red/white for sound
