20 Most Recent Sony KDL60EX700 60 in. TV Questions & Answers
Sony kdl 60ex700 red led blinks 3 times
Hi 3 Times Blinking is for the following reason DC_ALERT -------> DC_ALERT DTT_WDT --------> DTT Error AUD_PROT -------> Audio Abnormal Detection 3 time blinking-yhodbwzjdt0opvz5rorrwsay-3-0.jpg Kind regards. Rehan
11/11/2018 12:06:08 PM • Sony KDL60EX700... • Answered on Nov 11, 2018
Sony blinks 7 times
Hi 7 Times Blinking is for below reason TEMP_ERR Thermal Error FAN_ERR FAN Error (Not Detected. Display Only) Kind regards Rehan
11/11/2018 12:02:33 PM • Sony KDL60EX700... • Answered on Nov 11, 2018
Sony KDL-60ex700 When viewing any program
it may be your TV is in a STORE DEMO mode, please check the set up menu, switch it back to HOME MODE.
10/30/2017 1:28:24 AM • Sony KDL60EX700... • Answered on Oct 30, 2017
Blinks red 7 times
Check your owners manual for troubleshooting guide first. It could be something as simple as bad batteries in the remote.
8/18/2017 5:55:07 PM • Sony KDL60EX700... • Answered on Aug 18, 2017
My sony tv shuts off after 30 sec or so and blinks 4 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5/12/2016 11:20:50 PM • Sony KDL60EX700... • Answered on May 12, 2016
TV powers on and goes black.
first i'd say try all the normal things... swap sources, check to see if the osd comes up, etcetera. it might just be that the tv isnt receiving a signal from the source its tuned to. see if theres a way to factory reset the tv, try it. if no matter what you do nothing shows up... maybe the backlight burned out or maybe something on the mb burned out. go over and sniff the tv, notice any smell? if this is the case, i dont suggest trying to fix it new screen.
7/6/2015 6:29:49 PM • Sony KDL60EX700... • Answered on Jul 06, 2015
Green screen
Typical and serious fault. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience. Screen faults & possible causes to LCD screen are given with illustrations http://electronicshelponline.blogspot.com/
8/5/2014 2:10:30 PM • Sony KDL60EX700... • Answered on Aug 05, 2014
0answers
60EX700 r
Be the first to answer 3/22/2014 3:42:34 AM • Sony KDL60EX700... • Posted on Mar 22, 2014Be the first to answer
0answers
Hdmi input not working composite
Hello, The most likely solution to your problem is to go into the tv's settings and verify that the input (which ever the the number is) is not set to "skip" as that will make it appear as if it doesn't work. Just change the label for that input to anything but "Skip". Good Luck! Rich Lilja
12/28/2013 3:06:11 AM • Sony KDL60EX700... • Answered on Dec 28, 2013
Hello, The most likely solution to your problem is to go into the tv's settings and verify that the input (which ever the the number is) is not set to "skip" as that will make it appear as if it doesn't work. Just change the label for that input to anything but "Skip". Good Luck! I hope this helps. Rich Lilja
12/28/2013 3:00:11 AM • Sony KDL60EX700... • Answered on Dec 28, 2013
0answers
Standby light blinking
-Check your Manual look for something called blinking codes should be around page 9.-Please tell me you have a warranty, if not this can be expensive. Ranging from the main control board.- Have you tried cleaning bot ends of your LVDS Cables, this can sometimes remedy the problem.
8/27/2013 11:23:38 PM • Sony KDL60EX700... • Answered on Aug 27, 2013
My kdl60ex700 had about 20% on right side turned
Check its convergence adjustments. If you wish to get more details about how to do this, check this site. http://electronicshelponline.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
8/17/2013 7:22:51 AM • Sony KDL60EX700... • Answered on Aug 17, 2013
Kdl60ex700
And the problem would be WHAT?
8/17/2013 3:13:22 AM • Sony KDL60EX700... • Answered on Aug 17, 2013
Sony KDL60EX700 60 in. TV Logo
42 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
KDL Sony
  • KDL Sony
Most Popular Question
standby light blinking
  • Televison & Video
