20 Most Recent
Samsung LN46C630 TV Questions & Answers
Need owners manual for flat
Hello
To which model Samsung TV do you want to get the user manual? You have here stated two models of Samsung. If it is for Samsung LN46C630; I've the manual with me. If you send your email address to me, I'll send a copy of it to you by return mail. There is no model Samsung LN32B36065D with Samsung website. OK.
STUCK IN STANDBY
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Samsung 46 Inches LCD TV Model#LN46C630 Black Screen with Sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Is there a feedback circuit that is shutting down the high voltage power supply?
http://electro-medical.blogspot.com/
Samsung LCD seperated pixels
Though this is evidently a problem within the TV, just try changing the input device to some other like a DVD player and see. Look for any loose contacts in RC jack, cable and socket, as intermittent contacts can bring such funny looking problems, as the TV does not get time to recover from the making/breaking time. If problem persists, I recommend you call in a qualified service technician, as opening the back cover by others is not advisable.
