20 Most Recent
Magnavox 32MD359B 32 in. TV Questions & Answers
Magnavox 32md359b/f7
Main Board bad. The part number is A91F3-MPW S. Change this board fix the problem.
10/13/2019 6:35:07 PM •
Magnavox...
Answered
on Oct 13, 2019
Wont power on, replaced main board. "Standby" light comes on but TV still wont power up. What should I check?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
12/11/2015 3:40:50 AM •
Magnavox...
Answered
on Dec 11, 2015
Why is it stuck in standby?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
8/26/2015 6:51:14 AM •
Magnavox...
Answered
on Aug 26, 2015
What size wall mounting screws for a maganavox 32md350b
To know more about this, you should either download the repair manual to this set, or contact the authorized dealer for Magnavox. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
Disassemble procedure to some models of Magnavox TV are given. Check it first, please.
7/12/2014 4:16:49 PM •
Magnavox...
Answered
on Jul 12, 2014
In the combo tv and
The best way, in my experience, is literally disassembly. Pull the back off of the television and be very aware of the different ribbons connecting PCB's. Note where everything was plugged in (take pictures if you must), and find where the built-in DVD player is mounted (should be attached to the back cover). Remove the player and disassemble. It's generally fairly intuitive. You should be able to reduce it into a pile of parts and get your DVD out!
Word to the wise: I'm an electronic service technician, and I have seen a good many of these built-in DVD players fail. Actually, they all tend to fail within a year. They are also 30.00 units. No 30.00 unit has ever been even close to a good piece of equipment. That said, don't replace the internal DVD drive. Just buy a component player.
5/14/2011 5:59:44 PM •
Magnavox...
Answered
on May 14, 2011
Sound no picture but brittness
One of two causes applicable here. !- The t-con [or controller] on the back of the panel. {usually 4 x 8 inches in size. or 2- the digital processor board which can be identified by a post stamp ic made by ATI ....... Have changed numerous boards with the ATI ic on board.
Let me know what you find: Sam Farrell
2/17/2011 3:34:35 PM •
Magnavox...
Answered
on Feb 17, 2011
I get no picture and
Tv turn on now,u have a flashes of a picture only a few sec.than dies have sound left only?Yes,than the tv have a 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards for the replacement.
12/6/2010 7:55:33 AM •
Magnavox...
Answered
on Dec 06, 2010
