20 Most Recent
Samsung NX10 Digital Camera Questions & Answers
Where can I get a replacement eyecup for the
The part number is AD97-17740A (ASSY-RUBBER EP CAP;N) but a web search will bring back very few hits. As of late 2012, PartStore.com (in the states) could order the part (listed a "Special Order").
Broken plate
www.flex-007.com offers a replacement for nx 18-55 for $20. It'll take 10 minutes to replace though;)
What is a meaning of
Error 00 error message. Disconnect the lens and carefully
reconnect it when you see the "error 00" message with your Samsung
camera. The problem likely occurred because the lens wasn't connected
properly initially.
hope helps.
My Samsung Es90 digital camera's shutter is not working, plus, the batteries are fully charged but when inserted, it only last 2-3 minutes. What can I do to resolve this?
I'm assuming by "shutter" you're referring to the one inside the camera and not the cover blades on the very front of the lens.
How old is the battery and do you use the camera a lot?
Old batteries can be fully charged but can become weak and not hold that charge when the camera is powered on. The shutter issue could be part of this as the battery might not be strong enough to power the shutter.
I think the batteries for these cameras are reasonably cheap so you could invest in a new one to see if that helps. An extra battery is always useful if you use the camera a lot.
If this is an old, well used camera part do wear out so if new battery doesn't help you may need to take it to a good repairer as the camera will need to be taken apart to find the problem.
