20 Most Recent
3Com Baseline Switch 2948-SFP Plus 48-Port Gigabit (3CBLSG48-US) Questions & Answers
How do i Reset or break in to get reset my
The resetting of the password requires the installation of a console cable to the console port.
Be sure the terminal emulator program is set to VT-100 management
using compatible, 38400 baud rate, no parity, 8 data bits and Console
connection one stop bit.
Use the included cable, or be sure that the pin-out complies with a standard null-modem cable
Once the cable is connected, reboot the switch. Type a Ctrl/C until
you enter the failsafe mode. This will be denoted with the prompt:
“CFE>”
At the prompt execute the following commands:
CFE> passwrd
CFE> reset -sysreset
At this point the password has been reset.
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
