20 Most Recent Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Questions & Answers
Our garage door won't open all the way. It stops just short of being open all the way but not enough to get the car out. What is the problem? Can we fix it ourself?
Hello Pat Remus, Chamberlain... Has been around for a very long time ... type of door... presumed to be OVER-HEAD... Operation issues .... (were okay (?) sudden fialure is likely a BROKEN BALANCE SPRING EASY to check... CAUTION: doors can be EXTREMELY heavy. FROM the closed position... (to avoid a door crash)... You should be able to disconnect your GARAGE opener... and feel the well balanced motion rom the full open to FULL closed. If you hear any chatter of springs. THEY need to be lubed (often)... ELSE That "chatter" will turn into "SHATTER"... Those springs will break... and need to be replaced ( pretty RISKY job best done by a SERVICE company )... If the door is quiet & well balanced... Then it is time to check the "travel" contacts... and adjust them the the proper HEIGHT is achieved. >> READ THE MANUAL... OWNERS (model??) No exact matches found Try these results Hope this helps... Carnac the Magnificent
12/7/2017 4:05:36 PM • Chamberlain... • Answered on Dec 07, 2017
Just installed new Chamberlain motor but makes loud snap when door opens and closes about 3 inches from ground?
Do you have a security system in your home? Sometimes the door shut sensors get out of alignment and the door strikes the sensor. This is the exact same problem I had with my door.
11/8/2017 9:14:16 PM • Chamberlain... • Answered on Nov 08, 2017
Will a chamberlain belt drive work with genie safety sensors?
no, chamberlain openers require chamberlain, liftmaster, or craftsman safety eyes
9/16/2017 6:48:16 PM • Chamberlain... • Answered on Sep 16, 2017
Remote and garage door opener not communicating.
You may need to replace the battery in the remote control. Most usually these will be double A ones. You may have to reprogram it when you try it again. You should be able to get the information on Google by typing in the make of the inside unit in your garage. Your remote may have this info on it as well. You should be able to pull up instruction on how to reprogram your unit.
9/16/2017 1:05:50 AM • Chamberlain... • Answered on Sep 16, 2017
Chamberlain 1/2 hp opener stops intermittently during travel.
could be that the remote operation or cycle operation needs reprogramming as it indicates that the program has a corruption in it and the action is lost by that corruption follow the user manual and do the reprogram sequence
7/10/2017 12:00:33 AM • Chamberlain... • Answered on Jul 10, 2017
2answers
The motor squeaks both on the up and down modes.
I just installed this opener 1 week ago and the same thing happened. I remembered there is a "Belt Cap Retainer" that covers the motor sprocket and is held on with 2 screws. I removed the cover and the squeaking stopped. There is a small dab of grease (silicone?) that the instructions did not mention. I spread the grease around the cover next to were the belt travels and put the cover back on careful not to over tighten the screws. No more squeak!
11/28/2016 1:43:02 AM • Chamberlain... • Answered on Nov 28, 2016
Chamberlain garage door travel programming
Seems like you either have your photo cells out of alignment or disconnect from operator or a short in the photo cells wires.... make sure the you can see the green LED light on one and a amber/red on the other at the same time with no flashing or flickering. The green represents power supply to units and other color represents alignment, both are a must! so make sure you see them on solid without blinking or flickering.
10/17/2016 6:32:12 AM • Chamberlain... • Answered on Oct 17, 2016
Multifunctional control panel will not work when i tried to synchronize door control and light bulb on garage door does not light up?
I'm not familiar with the whisper drive but I would start with the most obvious place for a problem. There are two units at teach side at the bottom of the door jam. They have to be lined up for the door to work. This is the most frequent problem I have found because they are close to the floor and can be bumped out of alignment. Check to see if one of them have been moved. Most of these little plastic units have a plastic locator pin in the top of the unit. these pins snap into the mounting bracket. If the unit has been bumped just move the pin until it snaps back into the bracket. I'm not a contractor but I have seen this happen a lot with friends and family. Ask the easy questions first. Is it plugged in? Is the breaker in the power panel tripped? Good luck
4/27/2016 1:42:04 AM • Chamberlain... • Answered on Apr 27, 2016
2answers
Only the multi function control panel opens/closes garage door. Remotes and keyless entry do not work.
There's a lot of things that can cause range issues. Wireless routers to close to the garage. Bad LED or CFL bulbs. Faulty circuit board. A faulty motion detector on a light. Sometimes if you turn all of the breakers off except to the garage you can isolate it. If that doesn't help call a garage door company to come out.
1/15/2016 3:37:08 AM • Chamberlain... • Answered on Jan 15, 2016
Will chamerlain garage opener work with led lights
Yes but certain brands have been reported to cause range issues with the remotes.. If you contact Chamberlain that have a list of the brands and wattage to use.
9/28/2015 10:29:32 AM • Chamberlain... • Answered on Sep 28, 2015
How do ifix the garage door operation,to open and close properly,with the control and remote control ?
Make sure the dip switches on the transmitter match those of the receiver
8/9/2015 6:14:53 AM • Chamberlain... • Answered on Aug 09, 2015
After I replaced the screw drive sprocket coupler, Why doesn't the door open?
It is very easy to get these out of sync. The instructions tell you how to set this up. Be sure the operator is run to the closed limit switch. The belt should be at the closed position when these gears are installed. Verify that the door works well manually. Be sure the rope disconnect has been released to engage the operator (with the door closed). Follow the instruction sheet line by line. Good Luck Steve
5/6/2015 7:08:33 PM • Chamberlain... • Answered on May 06, 2015
2answers
My 2 hand held remotes will open garage door but will not close it I reset them but it still does the same thing can you help me?
My question is " does the door close if you use the button in the garage? If it does not close i would say your problem is in the main unit, or possibly your linkage is out of whack. If does close, check and see if your remotes need to be programmed for both opening and closing. It could be possible the garage unit isnt receving the signal to close. If it is getting signal, its not processing that command. I would also make sure my batteries are new, if they are weak, they may not have enough voltage when you hit your close botton. Hope that helps.
3/16/2015 11:22:47 AM • Chamberlain... • Answered on Mar 16, 2015
My garage door goes down than back up. how do i fix this? there are no obstructions that i can tell. the sensors seems to be lined up.
I ran into this a while back. check to see if there is any binding in the door as it goes up or down, see if everything is lined up.
2/27/2015 10:58:40 PM • Chamberlain... • Answered on Feb 27, 2015
How do I replace the motor and gear drive on Chamberlain MODEL hd900d OPENER
Purchase the full kit. Not the partial kit. The instructions come with the kit. Be sure to follow them. The position of the chain and the opener when you reattach the chain are Important. It's not beyond that the ability of a handy person.
2/21/2015 4:58:38 PM • Chamberlain... • Answered on Feb 21, 2015
3answers
Garage door automatically reverses if you cross the safety beam when door is in upward travel
something is wrong supposed to reverse on downward movement only as not to crush you.. in upward not supposed to do that.. call chamberlain 800 number
1/28/2015 9:45:24 PM • Chamberlain... • Answered on Jan 28, 2015
What does it mean when my chamberlain whisper drive openers eye sensors are differant colors? one is green andone is yellow
If one is green and the other is yellow if they are not blinking, or off. there is no problem at all
1/22/2015 4:11:37 AM • Chamberlain... • Answered on Jan 22, 2015
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
186 questions posted
Top Chamberlain Building Materials Experts
Jose Ramirez
ADMIN Andrew
ADMIN Andrew
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Chamberlain Building Materials
Most Popular Question
garage door automatically reverses cross
  • Building Materials
