20 Most Recent
Easy Quick Auto Jumper Recharges Vehicle Battery Without Jumper Cables Questions & Answers
I bought a 2000 pont. grand am gt 2 days ago and
It wont if any thing it will make it worse if u put to mush in check out ur theorem stat also check out fan switch on rad if not working replace it to check pull wires of and join to geather shud work if ok
What should I check to figure out the reason my batteries are getting drained ?
It sure sounds like you have a short somewhere, and BTW, good info. Not many people give much info, and without that you are shooting in the dark. The fact that several of your gauges don't work is very telling. Have you had like a hitch or new aux. fuel tank put on recently? Sometimes people don't watch when they install such items and they pinch wires and the problem doesn't show up for a while. As the insulation on the pinched wires sometimes take a while to wear through. Also I hope you are just taking off the negative(black) battery connections. You should always hook the positive first, then the negative. And with the key off you should not get any arcing/crackling sound from the connection when you hook it back up. If you do(which I'll bet you do) it means there is some circuit that is shorted or a relay is closed when it's not supposed to be. It's all about finding out what is hard wired(that means it's not wired through the key switch, it has the potential to be on all the time, but won't draw any current if the insulation in the wiring is ok, and the truck is off). Electrical probs are the worst. good luck.
1999 saab 9.3 makes clicking sounds and won't
Sounds like sticking contacts on starter motor will need to b removed and checked ,repair or replace starter motor the carbon brushes usually were down and don't make complete contact, just to make sure check and tighten batt terminals and connections on starter motor and earth wire on chassis
Battery keeps dying on my 2009 honda civic dx
you have a short somewhere in the vehicle try turning everything off and ignition fully off disconnect battery and then as you reconnect see what sort of spark you get if it's quite large there is still something drawing power put a meter between the terminal and cable to see what power its drawing if it's low try turning things on one at a time untill you get a surge that will point you in the right direction to the item thats drawing most power
My 1999 ford expeditin wont hold a charge i ve
hold a charge when, and stop guessing, please !state when and under what conditions.here, are some simple examples.car battery drains as i sleep (phantom drain, dark current)car battery drains, as I drive.battery will not hold a charge battery sitting on my work bench.just 1 clue? this is all easy, to fix. and find. post the full symptoms.
'05 Scion tc shocks me when exiting vehicle
Clrean the ground connection to the vechicle frame.Hook a peice of rubber strap from the rear frame long enough to contact the roadway , make sure the strap slightly drags when driving.
