20 Most Recent
Sony Cyber-shot DSC-WX1 Digital Camera Questions & Answers
How to switch language on japanese bought sony dsc-wx1 cybershot?
I
bought a camera in Japan (Sony Cybershot DSC-WX1) and now it seems that i
can't change the language from japanese to english. If i select (can't
read it but with the help of the english digital guide i think i have
the right menu)change language, there seems to be only one language
available. -japanese- How do I solve this?
Nhdp-w54 c6018 How to change the language from
Language Setting
Selects the language to be used in the menu items, warnings and messages.
1 MENU t
(Settings) t
(Main Settings) t [Language Setting] t
desired mode t z on the control button
I have a Sony Cybershot
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
How can i change the
Touch [MENU] to bring up the menu. Touch the toolbox icon. Touch the wrench-and-hammer icon. Select the third item on the menu.
Error: Turn the power off
Please make sure that the Camera is fully charged.
Please check if the Menu items in the Camera are accessible.
If accessible, please try initializing the Camera and check if that helps.
To initialize the Camera :
Please press MENU button of the Camera.
Then, Select the SETTINGS Menu (Briefcase icon).
After that, please select the MAIN SETTINGS (Wrench Hammer symbol).
Now, please select the INITIALIZE option.
Then, select OK.
The Camera will ask for initial settings of date and Time and language.
If the issue is unresolved after performing the above steps, the Camera has to be serviced.
Please contact the Authorized Service Center.
How to change language
Press the MENU button to bring up the menu. Select the toolbox icon, then the wrench-and-hammer icon, then the second item on this submenu.
How to switch language on japanese or chinese to
Press the MENU button to display the menu. Use down to select the toolbox, then press O (that's the center button on the multiselector). Use the cursor keys to select the wrench and hammer, then press O. Select the second item on that menu--that should be "Language". One of the choices should say "English" in English. Select that one and press O.
Press MENU to exit the menu.
The screen on my camera is black. You can still
This may be due to the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
The RESET button is located at the lower right side of the control button. To reset the camera, press the RESET button using a sharp-pointed object.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
My camera support only japanese language. It was a
English is in there...you'll have to scroll through the menu and all the sub-menus (I know....it's tedious) until you find the word "english"...when you do, click ok/select/menu and your language will change to english.
