20 Most Recent Radio Shack Accurian LMD-5108A Portable DVD Questions & Answers
Red charge light keeps blinking. does that mean the battery is dead?
Your user manual should provide some info. If not, consult with Radio Shack direct. I'm not familiar to this product so I can't tell you if the charger is defective or the battery needs replacement.
6/25/2014 7:14:03 AM • Radio Shack... • Answered on Jun 25, 2014
Why red charge light keeps blinking?
Is your battery a LiPo (Lithium?) If so ... These special batteries are charged by a computer circuit that holds the charge amperage constant and adjust upward the charging voltage until the required battery voltage is reached. At this time the charger hold a constant voltage and decreases the amperage as the battery capacity is "topped off". the charger circuit charges the entire battery at once but monitors each cell (cells are about 3.7 volts each) and controls the charge so that all the cells are ballanced. When one of the cells that makes up the battery starts to go bad, the ballance circuitry prevents over charging the others, so one weak cell hold all the cells back from full charge and better charger circuits will signal you with an led or such that the battery is' going' bad.
5/7/2014 1:23:34 PM • Radio Shack... • Answered on May 07, 2014
Need a new ac cord
Why don't u visit the Radio Shack stores litterly or try Radio Shack Store.com yet?Tries websites like Partstore.com,Amazon.com,Ebay.com to buy a a/c cord.
9/7/2011 6:12:47 PM • Radio Shack... • Answered on Sep 07, 2011
It keeps saying no disc
Lens could be out of alignment or the disc format is wrong.
4/4/2010 9:11:24 AM • Radio Shack... • Answered on Apr 04, 2010
2answers
I was given a gift
Hi and welcome to FixYa,
Initially, postback with the model number of the portable DVD player.
Offhand, if you would consider and try:
  • exercise the spindle motor by manually turning the circular bed where the disc sits on;
  • exercise the movement of the laser lens carriage by sliding it back and forth.
Good luck and thank you for asking FixYa.
12/28/2009 2:18:22 AM • Radio Shack... • Answered on Dec 28, 2009
2answers
Need replacement power cord for accurian Model No.
check on radio shack
9/6/2009 4:48:41 PM • Radio Shack... • Answered on Sep 06, 2009
Trying to program element TV with radio shack 5&1 remote
https://www.manualslib.com/manual/694349/Radio-Shack-Remote-Control.html
11/2/2022 8:51:43 PM • Radio Shack... • Answered on Nov 02, 2022
2answers
Radio shack do you have Homework converter box remote control
Sorry this is not Radio Shack.
10/20/2022 6:50:52 PM • Radio Shack... • Answered on Oct 20, 2022
I need a manual for a radio shack cat. no 63-1009a thermometer
notify radio shack
12/7/2021 1:21:35 PM • Radio Shack... • Answered on Dec 07, 2021
Program radio shack 4 in one remote for mishibushi ws65311 projection tv
read your instructions --or radio shack site for them
5/4/2020 12:34:05 PM • Radio Shack... • Answered on May 04, 2020
Have a radio shack universal remote need codes for Phillips tv
If you have the model number of the Radio Shack universal remote, that would help tremendously. There are several that were made. If it's the model 15-302, here are the codes to try. They may or may not work on other models. Philips 010,018,020,026,038,043,044,070,101,106, 134,139,150,151,205,210,217,218,257,267,285,290,302,303,314,325,382,396,400, 419,444,445
3/11/2019 6:20:59 AM • Radio Shack... • Answered on Mar 11, 2019
2answers
Need a code for radio shack 15-2133 , 6 in 1 remote for 60" vizio smart tv
This remote control have no set-up codes to Vizio. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
11/29/2018 8:04:02 PM • Radio Shack... • Answered on Nov 29, 2018
3answers
Do you have the codes to operate a universal Radio Shack remote, model 15-2142 for a Magnasonic DVD/VCR Dual Deck Model 825?
You can find the manual for the Radio Shack 4-in-1 Remote 15-2142 at ManualsLib and some other sites. A direct link to the PDF of the manual is here: http://www.rockabilly.net/files/manuals/15-2142.pdf . The ManualsLib version of the manual: https://www.manualslib.com/manual/635735/Radio-Shack-4-In-1-Remote-Control.html . The only code listed for a Magnasonic VCR is 0593. No Magnasonic DVD players are listed. If your Magnasonic DVD/VCR was built more than 6 months before the remote was programmed, then the remote has the best chance of having the correct code. The copyright date for the manual appears to be 1999. I hope this helps. You may want to try searching through all of the codes. Many electronics manufacturers use a common supplier for the IR sensor chip and encoding. Cindy Wells
9/28/2018 3:03:42 AM • Radio Shack... • Answered on Sep 28, 2018
Are there codes for a radio shack guide remote Cat. No. 15-2130
Codes would be for what .you are trying to connect to, not the remote itself
6/7/2018 5:51:40 PM • Radio Shack... • Answered on Jun 07, 2018
I've got an older Swan 8camera dvr set. No buttons to power on nor resethe with.. and I believe an adapter much larger has been used my mistake for power.. and now device will not power on..
Check for fuses first, Some fuses are soldered to the board and not easily identified unless you read the printing on the board. Over volting can cause filter caps to open as well as the power transformer winding's. Some transformers have fuses buried inside, Test the windings with an ohm meter. No reading would indicate an open internal fuse. Doing surgery on that type of transformer can restore it by taking the fuse out and joining the wires.
3/31/2018 5:59:48 AM • Radio Shack... • Answered on Mar 31, 2018
What is the code on a radio shack universal remote 15-302, looking for the code for a Phillips DVD/Blue ray player...
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
12/31/2017 7:41:27 AM • Radio Shack... • Answered on Dec 31, 2017
Radio Shack Accurian LMD-5108A Portable DVD Logo
9 questions posted
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Radio Shack Televison & Video
Most Popular Question
  • Televison & Video
