20 Most Recent
LG WM2301HW Front Load Washer Questions & Answers
Large loads won't balance & spin
Could be:
1. Broken spring(unlikely)
2. Bad shock absorbers (maybe)
3. Broken spyder-the Inner drum part that holds the drum to the hub(kinda likely). If inner drum can be moved without outer tub also moving in tandem, then broken spyder is likely.
Good luck
I recently purchased an LG WM2301HW washing
page 22 of the user manual states that warm rinses are regulated at 86F (30C) it states that there is a heating element as well to boost the temp to normal hot water temperatures (90-100 C)
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Grease like stains on clothing after washing
You have to clean the filter once a month. Which located lower left. Do a tub cleanse. Rinse extra. That will clear your problem. I have had the same issue and many repairmen and that was the answer. As long as I clean it than grease marks
