20 Most Recent Kenmore 24902 Top Load Washer Questions & Answers
2answers
Need to know procedure to clean Kenmore Series 80 filter
unbolt the agitator filters should be underneath let me know how you went
4/16/2019 3:53:24 AM • Kenmore 24902... • Answered on Apr 16, 2019
Washer will not advance past rinse cycle; leaks water from back.
Recommend contacting Kenmore directly for assistance Kenmore Customer Care Customer Service Information
1/28/2018 7:39:41 AM • Kenmore 24902... • Answered on Jan 28, 2018
DO YOU HAVE A TRANSMISSON BRAKE DOWN FOR KENMORE 110-20902990
I think there is some info about it in the manual: Kenmore Coldspot Model 106 Manual
7/15/2014 8:53:17 AM • Kenmore 24902... • Answered on Jul 15, 2014
0answers
My washer will agitate but won't spin nor drain.. what is wrong with it?
Check the lid switch. It is common for them to go bad. Check to see if it clicks when pushed down. the switch can cause the washer not to spin or drain.
6/25/2014 2:27:39 AM • Kenmore 24902... • Answered on Jun 25, 2014
Will agitate and spin when no clothes are in it but will not spin when loaded
It sounds like your clutch is wearing out.
5/17/2014 6:29:45 PM • Kenmore 24902... • Answered on May 17, 2014
Hot water only filling my Kenmore series 80 . I replaced my valve and still the same problem.
Swap the wiring to the valves, that will tell you if it's the valve or control board. You should/could also measure the voltage across the valve when it's supposed to be operating. If it's line voltage the valve is faulty, if not it's likely the control board. If the one you put in is new and tests ok then it's the control board feeding the valve, probably a thyristor or similar switching device faulty. If you aren't qualified BE CAREFUL THERE ARE HIGH VOLTAGES IN THAT AREA
4/29/2014 1:36:24 AM • Kenmore 24902... • Answered on Apr 29, 2014
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
4/19/2014 12:45:15 AM • Kenmore 24902... • Answered on Apr 19, 2014
Washer has filled but will not start
try to manual move to the wash option if it washes then stops after was it maybe the logic board ( brains unit ) not going to the next option. if it is a mechanical dial that rotates it will need replacing.
2/20/2014 7:35:35 AM • Kenmore 24902... • Answered on Feb 20, 2014
Kenmore 500 bangs when spinning
Sounds like the bearing in the drum has bust but shouldnt be too expensive to replace.
11/19/2013 10:34:02 PM • Kenmore 24902... • Answered on Nov 19, 2013
I have a whirpool washer and it fills with water
Remove pump and look for sock or frozen pump
11/9/2013 2:22:09 AM • Kenmore 24902... • Answered on Nov 09, 2013
0answers
2answers
WONT AGITATE OR SPIN
check the belt that spins the tub, you will find it at the bottom of the machine, check if its intact.
plz do not forget to vote if i solved your problem
1/27/2013 6:38:25 PM • Kenmore 24902... • Answered on Jan 27, 2013
Kenmore 24902 Top Load Washer Logo
261 questions posted
Alexander
vince
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
hot water only filling kenmore series 80
  • Washing Machines
