20 Most Recent Vivitar ViviCam 8025 Digital Camera Questions & Answers
4answers
How do u add music to ur video
The ViviCam does not record any audio. You can add a soundtrack using video-editing software on a computer.
12/22/2021 4:24:41 AM • Vivitar ViviCam... • Answered on Dec 22, 2021
I have a vivitar vivicam
Having gone over five months without a reply to my query, I assume formatting the card solved the problem.
9/5/2021 9:26:33 PM • Vivitar ViviCam... • Answered on Sep 05, 2021
2answers
I purchases a vivitar vivicam
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
The camera needs a memory card in order to save pictures. You can take pictures without one and view them on the screen, but those pictures are lost when you turn the camera off.
9/5/2021 9:24:36 PM • Vivitar ViviCam... • Answered on Sep 05, 2021
How to open battery door for vivicam F126
Well after looking at the manual, it is of no help but the pictures show it hinging open. Try pressing down and sideways along the compartment door from hinge line to outer edge. It it slides, it should unlock. Read reviews that indicated Vivitar customer support told an owner to visit a camera shop. Manual is on the CD included with the camera. Good luck.
12/24/2019 6:59:02 PM • Vivitar ViviCam... • Answered on Dec 24, 2019
What dose MSDC mean
Mass Storage Device Class: http://en.wikipedia.org/wiki/MSDC If your camera is saying this then it's either connected to your computer or thinks it's connected. With most cameras this is not an error but simply a notification that the camera is connected and can be used as a storage device but not as a camera.
2/28/2019 10:27:19 PM • Vivitar ViviCam... • Answered on Feb 28, 2019
2answers
Msdc
i have the same camera and the same problem but i have found out msdc means mass storage device, for the camera to work you have to have a memory card inside it. im getting one tomorrow for mine, so hopefully that should solve the problem :)
1/21/2019 7:17:31 PM • Vivitar ViviCam... • Answered on Jan 21, 2019
Where is there a sound button on a vivitar camera
most Vivitar cameras don't have speakers so if you want to hear the sound you either have to download the video onto your PC with the USB cable or play it directly from the camera using the USB cable and Vivitar software.
1/1/2018 5:42:06 AM • Vivitar ViviCam... • Answered on Jan 01, 2018
Mi problema es el que en mi camara vivitar cuando
The convention on this site is that queries are posted and answered in English, please.
8/2/2017 3:49:29 PM • Vivitar ViviCam... • Answered on Aug 02, 2017
HOW DO YOU TURN UP THE VOLUME ON A VIVITAR CAMERA
You don't. The 8025 doesn't record audio with video.
2/13/2017 8:36:51 PM • Vivitar ViviCam... • Answered on Feb 13, 2017
My camera keeps saying card
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
10/30/2016 3:47:26 PM • Vivitar ViviCam... • Answered on Oct 30, 2016
Vivicam 8025 what does the MSDC screen mean while charging
The MSDC indicates that the camera has recognized it's connected to a computer.The red light indicates that the camera's battery is charging.
7/4/2016 6:26:24 PM • Vivitar ViviCam... • Answered on Jul 04, 2016
2answers
"card protected"
If that doesn't work, try another card.
8/25/2015 2:37:26 PM • Vivitar ViviCam... • Answered on Aug 25, 2015
4answers
I need to know what the charger looks like. does
You can purchase a charger for this camera at http://www.amazon.com/Wall-Charger-Adapter-Vivitar-Vivicam/dp/B003M6BXBO/ref=pd_sim_e_1
3/30/2015 6:35:28 PM • Vivitar ViviCam... • Answered on Mar 30, 2015
How do i down load pictures on my computer off my camera
There are a couple of ways. The best is to remove the memory card from your camera and insert it either in the SD card slot on your computer if it has one or into a USB SD card reader attached to your computer. Your computer (Mac or PC) will recognize the SC card as if it were any add on USB device such as an external hard drive. Go into "Finder" if you have an Apple or "Explorer" if you have a PC and you will find the device. Open the device/folder. In most cases there will be one or two sub-folders. Open the folders and look for files with the extension ".jpg". Those are your pictures. You can now create a folder on your desktop or another location and copy and paste or cut and paste your photos into that file. The second method is to download the pictures directly from your camera using a USB cable. Although I am not familiar with your particular camera, there should be a small connector in which you can plug in the USB cable that should have come with your camera. Plug the other end into a USB port on your computer. The computer will recognize your camera as a device; just as it did in the first method. Again you can copy and paste your photos from your camera to your computer in the same way as I previously explained. The third method is to use a transfer program. Most, but not all, cameras come with one or there are many for sale. Adobe has that function in there Bridge and Lightroom software although you may consider it pricy. With the software installed you can either connect your camera to the computer with a USB cable or use an SD slot or card reader. The software will automatically download and display your pictures.
2/19/2015 1:25:38 AM • Vivitar ViviCam... • Answered on Feb 19, 2015
How do i turn Macro mode off my vivitar digital
There's a slide switch on the left of the camera near the USB port. Slide it away from the flower and toward the mountain.
7/9/2014 9:01:00 AM • Vivitar ViviCam... • Answered on Jul 09, 2014
Vivitar ViviCam 8025 Digital Camera Logo
918 questions posted
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
camera says memory full
  • Cameras
