20 Most Recent HP Photosmart Premium C309A All-In-One Printer Questions & Answers
An error 388
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395DefinitionThere is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time. SolutionRetry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
11/17/2022 11:37:06 PM • HP Photosmart... • Answered on Nov 17, 2022
My HP photosmart premium will not print black
Seems like the ink you are using is bad. It is thicker than what it is supposed be. If you are using HP ink, make sure it is not expired. If you are using a refilled ink or remanufactured ink cartridge, buy from someone else, not where you bought it last. You will need to clean printhead again. Also, to avoid this problem in future, the issue may be that there is too much ink gnk inside the printer. Where the printhead should sit on standby, the ink waste builds up. Clean that area with a butter knofe or plastic knofe. You may not have that issue of drying ink come back for a very long time. If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
7/25/2021 7:16:59 PM • HP Photosmart... • Answered on Jul 25, 2021
1. My printer displayed "USB Device Not
https://www.Abctay.com is an online shop , We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen, TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl , LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen , touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview, Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
7/25/2021 7:04:26 PM • HP Photosmart... • Answered on Jul 25, 2021
Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
7/19/2021 12:37:08 PM • HP Photosmart... • Answered on Jul 19, 2021
3answers
Printer won't print. General Printer beware spam number 1*800*532*4187
This Error code means unit has a carriage jam
Follow the link below to resolve the issue :
h10025.www1.hp.com/ewfrf/wc/document
3/7/2021 8:40:58 AM • HP Photosmart... • Answered on Mar 07, 2021
Error message 0x610000f6 won't re-set.
>try to do hardware reset
>while printer is on unplug power cord at the back of it, press and hold # and 6 buttons on your printer, while holding the buttons plug back power cord, printer should initialise you can release the buttons after 10 secs or until you see semi full reset on the display, if the printer will not automatically turn back on press the power button, if it ask for you to set the region and laguage again then you have done the reset successfully
>this hardware reset should clear the error otherwise better contact hp
8/1/2019 10:46:18 AM • HP Photosmart... • Answered on Aug 01, 2019
2answers
0xc19a0036
This is an ink system error.
First check the ink cartridges. Replace any that are low or empty. Remove the cartridges one at a time and check that the vent (on the top of the cartridge near the HP logo) is open. Remove any part of the orange tab that was left on by accident. If the vent is clogged, use a pin to unblock it. Then reinstall the cartridges and make sure that they snap into position. Close the access door and check the printer status in the control panel.
Attempt to run the printhead cleaning utility from the HP Solution Center (under Settings > Print Settings > Printer Toolbox).
Remove the printhead and clean it. Remove all of the cartridges, then lift the latch handle. Pull the printhead straight up. To clean the printhead you need lint-free clothes (coffee filters will work) and distilled or bottled water. Dampen the cloth with the water and wring out the excess. Then wipe the electrical contacts moving up towards the nozzles until all the old ink is removed. Do not touch the nozzles. Then clean the edge between the contacts and the nozzles, moving right to left (with the contacts towards you). Finally clean the ramps working away from the nozzles. Dry all the cleaned areas with another cloth.
Use another dampened cloth to clean the contacts inside the printer (move in a top to bottom motion). Then dry the area. Reinstall the printhead and lower the latch. Then reinsert the ink cartridges and close the access door. Check for the error again.
The next step to try is to reset the printer. With the printer on, unplug the power cord from the unit. Unplug the cord from the wall outlet as well. Wait at least 15 seconds and then reconnect the power cord to the wall outlet and then to the printer. Press the power button if needed to turn on the unit.
The final step to try is to replace the printhead. Unfortunately, if a new printhead doesn't work, the unit needs service and the printhead is not returnable.
There are pictures for the above solutions here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=en&cc=us&product=3737195#N65 .
I hope this helps.
1/30/2019 8:10:21 PM • HP Photosmart... • Answered on Jan 30, 2019
2answers
I bought a new hp
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.
Post / thumbs / testimonial are welcome!
1/30/2019 8:09:21 PM • HP Photosmart... • Answered on Jan 30, 2019
2answers
My c309a HP photosmart premium says (ink system
Have you reset the Machine? If not, follow the instructions;
Remove the cartridges, disconnect the usb, switch off, unplug the power chord, leave it off for few minutes. Again switch it On without the cartridges installed and without usb cable connected to it, press the power button several times while it boots up, and leave it on for few minutes, again shut it down using the power button and install the cartridges, connect the usb cable and restart your printer. This will fix your problem if there isn't internal/system failure/faulty.
Good luck.
Thanks for using FixYa.
1/30/2019 8:06:59 PM • HP Photosmart... • Answered on Jan 30, 2019
2answers
HP c309a printer - error message 0xc19a0036, have
1/30/2019 8:05:51 PM • HP Photosmart... • Answered on Jan 30, 2019
3answers
Print Envelopes with hp c309a "Paper Mismatch" error
Even though the icon on the printer shows the envelopes entering the printer narrow side first, you have to set the printer up for, and feed the envelopes through, wide side first.
4/21/2018 2:39:03 AM • HP Photosmart... • Answered on Apr 21, 2018
HP C309a will not scan on Mac 10.7.5
So, why would that surprise you? Mac is much different than Windows!
2/13/2018 11:57:40 PM • HP Photosmart... • Answered on Feb 13, 2018
I have a HP Photosmart printer model C309a. I
Go to troubleshooting and scan try YouTube
1/18/2018 2:39:13 AM • HP Photosmart... • Answered on Jan 18, 2018
0answers
HP Photosmart Premium C309A  All-In-One Printer Logo
835 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
error message 0x610000f6 re set
  • Office Equipment & Supplies
