20 Most Recent
LG 32LH40 31.5 in. LCD TV Questions & Answers
LG 32LH40 Firmware Update. Has anybody found one?
At the following website there are lg tv firmware updates but the 32lh40 is not listed. Likely you will need to contact lg support. I was looking for one just for general maintenance on the same model.
http://us.lgservice.com/vchip_html/V-chip_upgrade_for_your_set.html
When viewing live sports such
If you don't have your owners manual handy this link is to online one
manual . There are at least 3 things that can cause blurring images. What you are experiencing is motion or sports blur which is common on LCDs. 1. You need to go into your tv menu in picture setting look for "phase" can clear blurry images.2. Also in the "expert 1 and 2" settings where you can adjust "Tru-motion".3. Contrast if set too high can cause blurry images as well.
Also if you watch in SD as opposed to HD images look much more blurry in comparison. Play with the settings to see what works best.
Audio sync for a 32lh40
go to LG .com or just google what your looking for it will be a dowloadable file you put on a flash drive and insert in tv's usb port
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
