20 Most Recent Sony Bravia KDL-40V5100 40 in. LCD HDTV Questions & Answers
2answers
Tv turn itself off after 10 seconds
It sounds that the fault is with its main digital board. A start signal should come to the P/S board, from the main board, after the set is powered ON. Check whether this voltage comes to it. Refer to its repair manual for details. To get some details, http://electronicshelponline.blogspot.com/Pull up older posts.
7/8/2021 10:42:11 AM • Sony Bravia... • Answered on Jul 08, 2021
The wording "demo mode motion
You need to go into the TV menu and turn it off.
Press HOME, then select s_xmbs_set.icon.png > Picture & Display > Picture Adjustments > Motionflow > the desired option.
Good luck and let me know if this helps!
4/14/2018 8:14:45 AM • Sony Bravia... • Answered on Apr 14, 2018
Sony KDL-40V5100 Switches off by itself
Sorry to say but it sounds like your power supply is bad, although it is possible it is some other components in the TV because turning it off allows all diodes etc to power down completely. Unfortunately after a bit it happens again which leads me to believe again power trouble.
11/5/2017 1:19:23 PM • Sony Bravia... • Answered on Nov 05, 2017
I have a KDL-40V5100, The power cycles every 30 seconds or so as if it is trying to power on. I replaced the input board. The backlight is coming on at each cycles but it doesnt stay on.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
10/26/2016 1:45:31 AM • Sony Bravia... • Answered on Oct 26, 2016
2answers
TV powers on with no splash screen and then powers off.
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
1/10/2015 9:24:12 AM • Sony Bravia... • Answered on Jan 10, 2015
Picture has shadows
Sounds like a T'Con [Timing Control] board fault. In most Sony LCDs, this board will be built inside the display panel. If so, no other; except engineers at authorized service center for Sony can do anything. I advice you to contact the authorized service center for Sony; to get it repaires. Gopakumar Gopalan Google
3/11/2014 2:48:20 PM • Sony Bravia... • Answered on Mar 11, 2014
Sony kdl40v5100 just went out watching changed
Check the output voltages from the main power regulator. You must have the voltage list to proceed. Check all the low voltages carefully. If you wish to get the voltage chart, and other details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre
9/19/2013 1:21:38 PM • Sony Bravia... • Answered on Sep 19, 2013
Power board repair
Actually this is a very skilled work. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
9/19/2013 1:19:13 PM • Sony Bravia... • Answered on Sep 19, 2013
0answers
0answers
My dvd player is unable to be viewed when plugged into the tv
Where and how is it connected, also a simple step is try to either hook the player to another set or another player to this set, try to rule some things out.l
12/20/2012 1:45:06 PM • Sony Bravia... • Answered on Dec 20, 2012
14 blink
Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.Blinking codes for Sony and most of other brands of TVs are given in detail. Pull up older posts there. Sometimes, ads by the side and bottom of each post might help you to find the details of livability of spare parts too.
8/8/2012 5:51:14 AM • Sony Bravia... • Answered on Aug 08, 2012
2answers
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
6/30/2012 12:57:38 PM • Sony Bravia... • Answered on Jun 30, 2012
Sony Bravia KDL-40V5100 40 in. LCD HDTV Logo
58 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
kdl 40v5100 power cycles every 30
  • Televison & Video
