20 Most Recent
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Questions & Answers
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Kenmore gas range F11 error code
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
I have a Kenmore Elite
The F30 error code means the temperature sensor probe is open. First check the wiring, then check the probe. And if necessary, switch to a meat thermometer instead of a sensor probe. F31 is the error for a shorted temperature sensor probe.
Burner does not light
The burner is not level ,or you need to adjust the air flow on the end of the burner.
F90 error code Kenmore elite
The F90 error code is a door lock code. There are a couple of steps that you can take to try and clear the code. Do the following:
1) Unplug the range and wait for one minute.
2) Plug the range back in and turn it on.
3) Hold the door in and start a self clean cycle.
4) Wait for 2 minutes and then cancel the self clean cycle.
5) Do not let the door go until the door lock light goes out.
If that procedure does not clear the error code then you may have to get a Kenmore repair tech to take a look at the unit. There are a number of electronic fixes mentioned in their repair manual, but you would have to have the proper tools and training to run through those procedures. If there is any warranty left on the unit you can of course have the repair paid for. If not, then any repair shop should be able to give you a rough estimate on the cost of repair.
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
Cleaning melted plastic from oven
i found this on the internet..
For a regular electric
oven: Place a bag of ice directly on the
melted plastic to chill it and make it more brittle. Then carefully, using a razor-blade scraper, lift off the puddle of
plastic. This procedure will not hurt an interior porcelain finish. For a regular gas
oven: First turn off the gas..
plus you could go to this link if you need more help..
Cleaning melted plastic from oven Google Search
