20 Most Recent
Minolta Di3510f Bizhub Copier Questions & Answers
Que problemas significa el codigo
Remove the 3rd draw check for paper behind it ALSO REMOVE THE PAPER BEING STORED ON THE LEFT SIDE OF THE DRAW not a storage location it is use if you plan on placing 11x17 paper in the draw, if not above the motor is burned out and or worse case the main control board is bad, recommend you contact Konicaminolta dealership for the motor or the board if required Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Shows code C0BA0 and will
The out tray elevation motor failure, did some leave a trash can or some boxes below the output tray and they hit them:(:(:(. STORE NOTHING UNDER THE OUTPUT TRAYS!!!!. Rear cover of the finisher need to be removed, then the elevation drive motor assy removed BE CARE FULL THE TRAYS WILL FALL HARD FAST, so you most now how to that correctly Recommend a Konica Minolta Tech come out or the motor is bad worse case the control board for the entire finisher is bad!!!! Btw, I’m available to help over the phone in case u need at
Minolta Di3510 cannot make copies error code Co500
mam/sir,
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta 181 code c0070
Mam, Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
CODE 00500 MINOLTA Di3510
sir/mam First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
ERROR CODE C0860
DID you mean C-0960!!! C-0860 does not exist in the service manual. Check your bypass tray right side. For something jammed if no need to get a tech out for Konica Minolta. I believe there was a technical bulletin issued in regards to that error several years ago. Btw, I’m available to help over the phone in case u need at
Error code c0990
Bottom draw lift motor is jammed or burned out. Good chance its a bad gear located behind several gears in the front of the draw. This particular Gear sometime gets round out. When originally designed as a half moon. Btw, I’m available to help over the phone in case u need at
Error c0ba0
Your finisher elevation motor is failing or the sensors that monitor what and where the output trays are doing on their way up and or down. Tray hit some boxes stored under the bottom tray? some one leave a trash can and the tray hit it? Some one drop something on the tray. Away requires removing the rear finisher cover remove the elevation motor assy. BE CAREFUL if removed the TRAYS will FREE FALL. have to know how to handle that!!!!.Ensure trays move easy and does motor turn might have a bad motor. Btw, I’m available to help over the phone in case u need at
Minolta di351f c0070
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner install it correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you mite have a bad motor or the home sensor or acurator for the toner bottle is bad worse case the control board is bad Btw, I’m available to help over the phone in case u need at
