20 Most Recent Minolta DiALTA Di183 Copier Questions & Answers
How do I "insert plug-in counter"? What could be
the plug in counter is an add on accessory, please check that you have not changed any settings on the machine.
7/11/2022 11:41:58 AM • Minolta DiALTA... • Answered on Jul 11, 2022
How do I stop the maintenance indicator light in Minolta di183 photocopier? pls help
Clear the maintenance counter in service mode.
2/18/2019 4:07:36 PM • Minolta DiALTA... • Answered on Feb 18, 2019
0answers
I have error code: C0070: Service Call
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/21/2015 5:10:50 AM • Minolta DiALTA... • Answered on Nov 21, 2015
My photocopier minolta di 183 is giving me error
Well need to replace the drum and developer running F8 with out changing the developer is not good, also make sure you clear the counter before replacing the drum and developer done toghter Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/31/2015 12:18:10 PM • Minolta DiALTA... • Answered on Mar 31, 2015
Minolta di 3510 is giving me an error code
manual by pass tray the tray on the right side of the machine is in op. Check for a jam that might not be letting the tray raise near the machine. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/2/2015 3:51:09 AM • Minolta DiALTA... • Answered on Mar 02, 2015
Dialta Di183 error message C0045
replace fusing unit cooling fan try the web site below as a start for the part Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/1/2015 8:04:43 PM • Minolta DiALTA... • Answered on Mar 01, 2015
Bonjour que signifie le code
replace the developer and the drum Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/1/2015 7:57:08 PM • Minolta DiALTA... • Answered on Mar 01, 2015
Cannot close the M1 part
M1 is a counter for maintenance need to get service mode access to clear the counter and clear the message. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/1/2015 7:39:27 PM • Minolta DiALTA... • Answered on Mar 01, 2015
I get an error code on our Minolta DiAlta Di183
Press the panel reset screen until intial screen appears Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/1/2015 5:05:12 AM • Minolta DiALTA... • Answered on Mar 01, 2015
Error code C0601 Error code C0072
for the 0072 try this:
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad As for the 0600 code the scanner the bright lite under the big glass is not lighting replace the lamp and board as for the Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/1/2015 4:10:50 AM • Minolta DiALTA... • Answered on Mar 01, 2015
I have Dialta di 183
Does show any code on the screen like C0500 or something like that try turning it on with the stop button held down to reset the fuser (THE HOT PART) also check make sure the electrical plug is plugged into the machine tight and snug, if not sound like a power supply problem, might want to get a konicaminolta tech to come out a look at it. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 4:27:24 AM • Minolta DiALTA... • Answered on Feb 22, 2015
How to reset display nc2 of dialta183 model
Drum and developer need to be replaced and the counters cleared and the F8 run once the new developer is installed NC2 will go once that is done. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 1:53:09 AM • Minolta DiALTA... • Answered on Feb 22, 2015
HOW TO ENTER SERVICE MODE ON LJ 4730
HP Color LaserJet 4730 Multifunction Printer Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 1:13:58 AM • Minolta DiALTA... • Answered on Feb 22, 2015
Dialta 3510 error code "insert
what code sir/mam? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/20/2015 4:29:13 AM • Minolta DiALTA... • Answered on Feb 20, 2015
Networking di183 printer
try this web site Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/20/2015 1:50:52 AM • Minolta DiALTA... • Answered on Feb 20, 2015
Minolta Dialta Di183 network configuration settings
Self Help Product Support Konica Minolta Business Solutions Inc try this web site for op manual and drivers Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/20/2015 1:50:29 AM • Minolta DiALTA... • Answered on Feb 20, 2015
Minolta DI 183 error code FFC03
Never seen 5 Letter/number normally it C-13F0 or something like that please check again Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2015 4:23:14 AM • Minolta DiALTA... • Answered on Feb 19, 2015
Minolta Di183 PCL6 won't print on network
Self Help Product Support Konica Minolta Business Solutions Inc try this site for drivers Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2015 12:34:49 AM • Minolta DiALTA... • Answered on Feb 19, 2015
Minolta DiALTA Di183 Copier Logo
95 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
stop maintenance indicator light in
  • Office Equipment & Supplies
