20 Most Recent
Armitron Digital Sport 406623BLK Watch Questions & Answers
Instructions for Armitron All Sport 40/6623 time
Here's how you set the 40/6623 M175 for anything. I figured it all out with help from here :). Okay so want to set the alarm? Press MODE once. Then hold it. And use the DATE and ALARM buttons to set the alarm. Press MODE twice and you're done. To set time do the step before this and press MODE once. Use the DATE and ALARM button to set the time. As for the 24 hr deal what you do is hold ALARM and press MODE or hold MODE and press DATE. To turn alarm on/off hold ALARM button and then press the DATE button. To set the date go to time set mode and keep cycling between the hours and mins until you get to the date :). That's all you gotta do :D. I know many of you need the instructions so here it is!!
Armitron Ladies digital Watch
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
As your watch is an older model it may not be on their web site. If not, contact them to see if they have a copy in theri archives.
Watch not working!...
mcdevito75 here, Sadly, once a battery, any battery leaks, it leaks out acid that eats away metal. Once your watch Battery leaked acid, it ate away electrical contacts, wires as thin as hairs, and tiny linkages with--in the quartz movement of your watch, ----- there is no reversal of this acid corrosion. You have 2 choices, 1 and if this is possible, have your watch repair person replace the quartz movement with a new one, if replacement movement is available, and 2 replace the entire watch. Sorry.
How to i set it to regular time from military
instructions.
I'm tring to find out how to set my watch. I lost
You can get a set of instructions by going to their web site "amitron .com"
Select "support" and "watch instructions" and a list of diagrams will appear. Choose the one that looks like yours and download you instructions.
