20 Most Recent Replay XD 1080 Video Camera Complete System-Motocross Gear Questions & Answers
My 2000 Dodge Caravan is leaking oil from what
Here's a link Frank,should help.
9/29/2013 11:03:51 PM • Replay XD 1080... • Answered on Sep 29, 2013
Hi all so I have a Aprilla Pegaso 650 57 plate its been stood nearly 2 years and just won't start
It has fuel injection and yours isn't working. In the 'old days' you would have just stripped, cleaned and rebuilt the carburetor. Now you need dealers with scan tool computers to diagnose and fix. The first thing to check would be the fuel pump, which supplies the pressurized fuel to the injectors. https://www.motorcyclenews.com/bike-reviews/aprilia/pegaso-650/1997/ ..
11/8/2022 6:46:13 AM • Motorsports • Answered on Nov 08, 2022
Firing order
you need to post what engine you need firing order for
11/30/2017 1:30:16 PM • Motorsports • Answered on Nov 30, 2017
Where is the lighter fuze on a vw polo
in manal that you have recived in the car should be explained what every fuse is doing.
5/31/2017 1:12:46 PM • Motorsports • Answered on May 31, 2017
I just fitted a gianelli exhaust expansion to my old Yamaha DT125 lc -87. The bike lost 20km/h with the new exhaust. It revs better and accelerates better but when I get it to 100km/h with 3rd gear at
Go to a smaller exhaust or a longer exhaust (not practical. Engines need some back pressure. That is why headers on dragsters are all of equal length.
5/30/2017 3:16:30 AM • Motorsports • Answered on May 30, 2017
7answers
Going from synthetic blend oil to a regular premium oil? Any adverse complications?
First of all let me tell you that it is a myth that you can not go back and forth between conventional oil and synthetic or in your case synthetic blend. They all mix very well together but why on earth would you not use a full synthetic in every thing? It will keep your motor so much cleaner, and last way longer, new or 150.000 miles used, does not matter. They refine the synthetic oils way way longer to get the impurities out. Other big thing [ OILTEMPERATURE AND WEAR COLD START UPS ] Exceeds and blows conventional out of the water. plus a real full synthetic you can run a lot longer just spin a new good grade filter on or change it. Me my self Ill run Walmart full synthetic in my grand prix and ROYAL PURPLE in my 2013 mustang. I think there all full synthetics are good compared to the old dirty sludge and if all the new manufactures are recommending it now its good. Do you have any motor rebuilders or trucking builders close to you? Just go look at the oil pans to compare the too . I guarantee you will be sold that day and never run conventional again.... PERIOD.
2/9/2017 12:59:28 PM • Motorsports • Answered on Feb 09, 2017
2answers
How do I found good auto repair shop at Las Vegas ?
Call around, the one that is busy is the one you want.
2/2/2017 7:10:03 PM • Motorsports • Answered on Feb 02, 2017
I would love to know if anyone knows of a trophy top from the 50's called a Jalopy and resembles a '32 ford 5 window coupe. no fenders, square hole in roof and brass plated. I broke my dad's first 1.
call around the ford veteran and modified car clubs to see what information you can get they are the most likely people that can help you
12/21/2016 11:25:32 PM • Motorsports • Answered on Dec 21, 2016
1996 Ford explorer speedometer doesn't work
coudl be the speed sensor. or trans computer
11/1/2016 1:18:24 PM • Motorsports • Answered on Nov 01, 2016
2answers
I have a 2001 volkswagen it has started losing speed after going 70 miles and hr. for about 7 miles it start to miss in the motor and my speed goes from 70 to 50 in seconds if i push the accelerator d
A flashing SES light is a misfire and can cause severe engine damage. You need to have the computer scanned and post the codes here for more help. It could just simply need a tune-up.
11/1/2016 12:40:43 PM • Motorsports • Answered on Nov 01, 2016
2answers
What is the illuminated "E" represent next to the drive indicator?
economy ?
10/23/2016 5:51:13 AM • Motorsports • Answered on Oct 23, 2016
3answers
02 toyota corolla will start but not run.longer than 5seconds
Check fuel pump pressure, fuel filter for clogged, fuel line if purged, fuel tank valve which is attached to the chassis above the fuel tank.
8/22/2016 6:45:54 PM • Motorsports • Answered on Aug 22, 2016
Engine hot/ac off what causes this
Most new generation cars has this feature to warn you that something is wrong. To explain further when your auxiliary fan is not working on the engine is hot, this causes the high pressure side on your ac system to reach around 350 psi and thru a sensor cuts off the ac compressor. This causes the ac not to work until the pressure goes back to normal.
6/13/2016 2:57:19 PM • Motorsports • Answered on Jun 13, 2016
How to test an armature
With a growler and a hacksaw blade cut to the correct length
3/6/2016 6:59:02 PM • Motorsports • Answered on Mar 06, 2016
Poor idle
remove fuel pump relay run engine till it stops (no fuel pressure in line remove clamps with hose clamp pliers wqe7ruull fule lines from filter then undo the clip at the other end of the two short pieces of fuel line and discard insert the two new pieces of fuel line in the kit put the 4 hose clamps on the new fuel hoses 2 on each insert the filter into the flexible hoses and refit the two hose clamps replace the fuel pump relay turn on ignition and wait for fuel pump to stop start engine + check for fuel leaks at filter or hoses
3/6/2016 11:48:42 AM • Motorsports • Answered on Mar 06, 2016
Clutch asssembly ford 1998
pressure plate clutch plate thrust bearing pilot bearing or bush (really important} slave cylinder or clutch cable (if not hydraulic} brake fluid brake bleeder (vacuum or pressure} lubricant for the bearing (HTB grease} or lubricant for the bush (engine oil ~ soak for 24 hours before inserting lubricant for the clutch cable if not hydraulic (10w oil} Clutch Alignment tool (old 1st motion shaft} / universal alignment tool an assistant ~ someone who works for love beer or money workshop manual for specs eg torque setting for pressure plate bolt
3/6/2016 11:41:22 AM • Motorsports • Answered on Mar 06, 2016
Remote start wont work when car is backed in?
Sensor is out of range as the signal is not being reflected directly to it some tin foil on the wall of the garage in the right spot will do the trick
3/6/2016 11:28:30 AM • Motorsports • Answered on Mar 06, 2016
3answers
Vehicle runs and then dies
need more info please to wot the problem is ! wot engine etc ! how does the problem start etc ? P.....
3/6/2016 5:59:50 AM • Motorsports • Answered on Mar 06, 2016
6answers
How do I go faster to beat them
Simple Assuming the cars are of equal calibre, just hold the pedal to the metal for longer, brake later & accelerate as fast as possible if not braking or cornering. That is the winning formula. Otherwise get a faster car
3/6/2016 1:26:38 AM • Motorsports • Answered on Mar 06, 2016
Replay XD 1080 Video Camera Complete System-Motocross Gear Logo
2 questions posted
Top Replay XD Motorsports Experts
Drerangula Siva...
Drerangula Siva...
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Replay XD Motorsport Expert? Answer questions, earn points and help others
View Most Popular
  • Replay XD Motorsports
Most Popular Question
2000 dodge caravan leaking oil from
  • Motorsports
