20 Most Recent
Red Defy Helmet Youth 2012 Questions & Answers
My double door firge frezeer is not icing and the
Glori,you mite need to replace your thermostat,...... the alarm button is telling u that your fridge is not cold enough, there is also probably another prob but u need to b a electrician to sort it on the top of fridge there is a panel,.. under that there is a fusible link if one blows it will need to b replaced its soldered in no job for u unless ur a electrician hope this helps
MANUAL FOR DS640
wrong forum , this is, cars/trucks. sorry.
ah, snow boarding, what makes you think htere is a manual
put on head, adjust strap, if dirty clean with mild soap and water.
Firing order
you need to post what engine you need firing order for
11/30/2017 1:30:16 PM •
Motorsports
Answered
on Nov 30, 2017
Going from synthetic blend oil to a regular premium oil? Any adverse complications?
First of all let me tell you that it is a myth that you can not go back and forth between conventional oil and synthetic or in your case synthetic blend. They all mix very well together but why on earth would you not use a full synthetic in every thing? It will keep your motor so much cleaner, and last way longer, new or 150.000 miles used, does not matter. They refine the synthetic oils way way longer to get the impurities out. Other big thing [ OILTEMPERATURE AND WEAR COLD START UPS ] Exceeds and blows conventional out of the water. plus a real full synthetic you can run a lot longer just spin a new good grade filter on or change it. Me my self Ill run Walmart full synthetic in my grand prix and ROYAL PURPLE in my 2013 mustang. I think there all full synthetics are good compared to the old dirty sludge and if all the new manufactures are recommending it now its good. Do you have any motor rebuilders or trucking builders close to you? Just go look at the oil pans to compare the too . I guarantee you will be sold that day and never run conventional again.... PERIOD.
2/9/2017 12:59:28 PM •
Motorsports
Answered
on Feb 09, 2017
