20 Most Recent Konica Minolta magicolor 1690MF All-In-One Laser Printer Questions & Answers
The problem is in weakened solenoid's (SD2) spring (10). That solenoid located under metal cover (13) on left side of 1690MF (if look at front of them). Required solenoid has red wires. Remove metal cover with 3 screw, unscrew solenoid and just slightly stretch spring (10). That is all.
Konica Minolta... | Answered on Sep 05, 2019
for what counter are you resetting?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Jun 18, 2019
check paper tray
Konica Minolta... | Answered on Jun 13, 2019
If it got jammed in the fuser unit (the hot part) the fuser can come out as a unit then remove the media wad
Konica Minolta... | Answered on Mar 02, 2019
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
Konica Minolta... | Answered on Feb 12, 2019
image cartridge for that color y-yellow, c cyan (blue) m magenta (red) k = black replace it
Konica Minolta... | Answered on Mar 25, 2018
your drum unit need to be replaced
Konica Minolta... | Answered on Mar 10, 2018
Sir/Mam,
You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since someone attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inoperative , once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine now a day have Bank Note chips.
Konica Minolta... | Answered on Mar 04, 2018
2 transfer roller issue open the located across from the transfer belt sponge looking roller check it
Konica Minolta... | Answered on Feb 25, 2018
Enter in the service mode,select counter mode and select special parts mode.
Konica Minolta... | Answered on Aug 26, 2017
Code has to deal with 2nd Transfer roller the sponge looking roller across from the transfer belt
Konica Minolta... | Answered on May 07, 2017
Transfer roller issue. the sponge looking roller across from the transfer belt.
replace it
Konica Minolta... | Answered on Jul 09, 2016
what is Booth room mode??????
Konica Minolta... | Answered on Jul 05, 2016
Have a tech come out re-flash the copier OS. Firmware is only available thur secure web site
check all image units and fuser also check the transfer belt, something is stopping th main transport motor replace the all ave worse case motor is burned out along with main control board$$$$$$$$$$$$$$$$$$$$$$$$$$
Konica Minolta... | Answered on Jul 04, 2016
PRINT HEAD which houses the LASER replace it, or the control board
Konica Minolta... | Answered on Jul 03, 2016
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
223 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Magicolor Konica Minolta
  • Magicolor Konica Minolta
Most Popular Question
konica minolta 1690mf causing fuser
  • Office Equipment & Supplies
