20 Most Recent
Samsung SL30 Digital Camera Questions & Answers
Driver samsung sl30
Samsung doesn't offer official downloads assuming that your camera will plug&play on the computer automattically.
However, try to download the whole pack of Samsung driver downloads from here: http://rapidshare.com/files/226025988/SamsungMaster1114_17062008.zip
How can I open the case of my Samsung SL30 camera?
I wouldn't try to open the camera lens to that extent to clean it out, you will have to disassemble dozens of tiny parts, springs, leaf shutters, tiny screws, gears, motor.....etc. It is rare that you get dirt inside the lens, maybe it is something else outside the lens?
Computer does not recognize USB from samsung ES70
Try not connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Software for samsung sl30 digital camera
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Picasa will also give you just about all of the photo editing capabilities you're likely to need short of a professional program such as Photoshop. And it's free.
Software for samsung sl 30 digital camera
Samsung sl30 usb not connection to computer
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
I need to download the
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
My camera card says it is locked....
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
The lens is stuck
try taking canned air to the lens joints.it could be just dirt or something blocking the sensor or the lens itself from retracting.
Camera says "card locked" when I try to take a
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. There are also other common causes if the above didn't help, with troubleshooting steps for this problem
listed here.
Laptop dont recognize the camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
[email protected] I put new batteries
Base from the description of your problem , it seems that something on the battery compartment is grounded that it easily drains the battery life even with a new one.
In order to correct this use the camera needs to be check and have the connections on the battery compartment be corrected to avoid that ground in there , it will be better if you can take it to service center near your area.
