20 Most Recent Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera Questions & Answers
Hello my nikon coolpix s220
Do you mean the lens, or the LCD screen ? Either way, with equipment this old, repair is not economically viable - get a new one, and treat it with care.
7/19/2017 7:57:48 AM • Nikon Coolpix... • Answered on Jul 19, 2017
Blurred pictures
You may be using too slow a shutter speed, resulting in either camera shake or subject movement. See what the manual has to say on this.
6/29/2017 2:31:12 PM • Nikon Coolpix... • Answered on Jun 29, 2017
2answers
My nikon coolpix s220 has a lens error, as soon as
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
4/28/2016 5:09:36 PM • Nikon Coolpix... • Answered on Apr 28, 2016
I can't transfer images from camera to pc
well, You didn't say what method you sre using?I will assume a USB cabke, Pick up a Card Reader at Walmarts - they are cheap and easy to use.
2/9/2013 4:54:45 PM • Nikon Coolpix... • Answered on Feb 09, 2013
Who are your authorized dealers in Kenya who can
Hi,bring it at highpoint technologies,located at luthuli ave near tawi hotel,we ave the solution for all your digital and video camera or email us @ [email protected]
8/1/2012 7:22:19 PM • Nikon Coolpix... • Answered on Aug 01, 2012
What's your problem? Nikon Coolpix S220 - My screen is black and takes black pictures. I can still look at old pictures that are saved to the device and see how much battery power etc, but it will
i can recommend read very well you owner manual specially the troubleshooting section. The images in the LCD monitor will darken in strong sunlight or bright light. This is a normall occurrence the devices containing CCDS, and doesnot contitute a malfunctions.If you are using too much the flash+zoom, the batteries quicly will drain. maintian another set of batteries for replace, or better buy recharges batteries.God bless you
8/1/2012 6:29:28 AM • Nikon Coolpix... • Answered on Aug 01, 2012
Memory card is write protected ????
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
4/29/2012 4:48:15 PM • Nikon Coolpix... • Answered on Apr 29, 2012
My camera seems to be locked on the internal
You need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format". Follow the on-screen instructions to erase the internal memory. After that, your card should work properly.
11/7/2011 10:02:25 PM • Nikon Coolpix... • Answered on Nov 07, 2011
I dropped my camera and now it is saying lens
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
10/13/2011 11:46:49 PM • Nikon Coolpix... • Answered on Oct 13, 2011
WHITE SCREEN NO PICTURE
when the lcd screen is black or white,the best solution is for a replacement,change the lcd screen immediately.The nikon s220 lcd screen is not in a high price,you can buy it and fix it by yourself.http://www.skiliwah.cn/http://www.digitalcamera-parts.net/e-mail:[email protected]
10/13/2011 5:43:39 AM • Nikon Coolpix... • Answered on Oct 13, 2011
Vertical lines running through video when I view
Sound like a malfunctioning CCD-image sensor. Rare, but possible problem with your LCD screenviewer... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your technical service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Applied warranty, if underwarranty yet. Dont forgetted to ratings and leave an testimonial comment about this free answer.
Hope this helps.
10/10/2011 7:45:25 PM • Nikon Coolpix... • Answered on Oct 10, 2011
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
10/8/2011 4:42:35 PM • Nikon Coolpix... • Answered on Oct 08, 2011
Cramer dropped. Now lense will not retract and I
I have a solution to your problem but the staff at fixya.com won't let me send it to you.
9/30/2011 3:44:00 AM • Nikon Coolpix... • Answered on Sep 30, 2011
Can i charge nikon s220 with nikon EH-68P charger
No you can't (shouldn't) it is not compatible.
9/28/2011 1:02:32 AM • Nikon Coolpix... • Answered on Sep 28, 2011
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
191 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
memory card write protected
  • Cameras
