20 Most Recent
Arctic Cat 2008 CrossFire 8 Questions & Answers
Arctic cat zr900
Open your chain case. Youll probably find your chain laying in the bottom.
Snowmobile dies will driving
Next time it dies, grab a spare spark plug and see if it is Sparking. If it is Sparking (which I doubt), you have an electrical issue. Some have CDI's and some have Coils (I am not a CROSSFIRE EXPERT), If there is Spark, I would check the Compression
600 triple engine bogs
There's a number of things it can be first check throttle switch bypass all switches at the base it it still bog stator
2008 90 atv
If you dont have a fuel problem,change the external coil.
Arctic cat problems
Sounds like you have one of a few issues:
Clogged Main Jets
Cut Off on the Throttle restricting your running
Compression Test the Engine and see that the PTO Cylinder is at least a 110-120 Compression and the split between is not more than 10 psi
