20 Most Recent
Arctic Cat 2009 CrossFire 8 Sno Pro Questions & Answers
How to replace spark plugs
Spark Plugs are screwed into the Top of the Head. Do not over tighten, applying anti-sieze will not hurt but normally will not be an issue to begin with.
600 triple engine bogs
There's a number of things it can be first check throttle switch bypass all switches at the base it it still bog stator
2008 90 atv
If you dont have a fuel problem,change the external coil.
Arctic cat problems
Sounds like you have one of a few issues:
Clogged Main Jets
Cut Off on the Throttle restricting your running
Compression Test the Engine and see that the PTO Cylinder is at least a 110-120 Compression and the split between is not more than 10 psi
