20 Most Recent Hampton Bay 24750 Huntington III Ceiling Fan Questions & Answers
3answers
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
1/4/2024 10:43:35 AM • Hampton Bay... • Answered on Jan 04, 2024
4answers
Remote control replacement.
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for the various brands including Hampton Bay...
11/25/2023 1:13:00 AM • Hampton Bay... • Answered on Nov 25, 2023
Need a replacement remote for a Harbor Breeze fan 52 inch Yorkshire ceiling fan
Hey, hope you are doing well. I was able to source a replacement remote for you. The model number you are looking for is uc7080t for the replacement remote that works with the Harbor Breeze Yorkshire fan. https://remotecontrolplace.com/harbor-breeze-replacement-remote-controls/replacement-remote-uc7080t-for-harbor-breeze-and-hampton-bay-ceiling-fans/10_16_2022_2_01_08_am.jpg
4/17/2023 2:32:31 AM • Hampton Bay... • Answered on Apr 17, 2023
3answers
Looking for an owners manual for a Hampton Bay
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
8/6/2022 5:15:29 PM • Hampton Bay... • Answered on Aug 06, 2022
2answers
Need a new blade
8/6/2022 4:11:39 PM • Hampton Bay... • Answered on Aug 06, 2022
2answers
Need replacement blades
Although we do deal with Hampton Bay fans ourselves, here's a link to someone who does:Contact Mike Evans
Website: www.eceilingfans.com
Phone: 979-553-3260
Ceiling Fan Parts & Service
8/6/2022 3:57:46 PM • Hampton Bay... • Answered on Aug 06, 2022
3answers
Need remotes
In theory, they should. Try Hampton Bay first, and if not, check for aftermarket replacements. Those remotes are simple enough that there is no reason that they can't.
8/6/2022 2:30:27 PM • Hampton Bay... • Answered on Aug 06, 2022
Hampton Bay ceiling fan quit working. No lights, no fan operation at any setting. Replaced remote battery and checked dip switches for correct position. Wall switch is on and has power through it (c
IIt sounds like there is not power to it, so it could be a loose wire nut on the "hot" side of the circuit inside the fan junction box. That's going to be a pain to get to. If you have power there and the connection is faulty, that's the problem. If you have power there and the connections are good it should operate manually without the remote. If not, I would suspect the fan is DOA.
3/5/2020 3:39:55 PM • Hampton Bay... • Answered on Mar 05, 2020
2answers
Can a remote control be installed on the Huntington III?
Yes you can operate them with two styles of remotes: either the remote wall switch, or a hand held remote. Both require the receiver to be mounted above the top of the fan in the base it is wired to. The receiver has wires on both sides; the one side wires directly to the house wires, and the other goes to the fan and light. They are both sold at Home Depot and Lowes. The ones at Home Depot also include the set made by the fan manufacturer.
7/11/2019 10:18:32 AM • Hampton Bay... • Answered on Jul 11, 2019
3answers
Ceiling fun
home depot and lowes carry hampton bay products, go to ceiling fan area and replacement blades and hardware are sold in packs of four and five. cheaper than buying a new fan. hope this helps.)
7/2/2019 8:21:22 AM • Hampton Bay... • Answered on Jul 02, 2019
4answers
I want to install a ceiling fan. My ceiling is 80
mcdevito75 here, Hopefully your ceiling fan will go where there has been an already light fixture, if so, that light fixture shoud be mounted to the ceiling beam, and your new fan will be mounted the same way. If by chance your new ceiling fan is being mounted where nothing was ever mounted you"ll have to make sure the ceiling fan will mount to a beam, they are every 16 inches apart. This way you:"ll know that vibration from the fan won"t hurt anything.
6/25/2019 5:58:48 AM • Hampton Bay... • Answered on Jun 25, 2019
3answers
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
4/17/2018 5:40:25 PM • Hampton Bay... • Answered on Apr 17, 2018
2answers
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution. 4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09. How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch: old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use: L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black 1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray 2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown) 3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple 4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use: L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black 1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray 2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green) 3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown 4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
9/30/2017 9:28:59 PM • Hampton Bay... • Answered on Sep 30, 2017
2answers
I need to reverse direction of fan
mcdevito75 here, Close to the ceiling but still on the fan motor shroud should be another small pull chain switch, this pull chain switch is the fan reverse switch, the switch may also be a toggle switch but I doubt it. Look close to the other pull chain switch for the fan, for the reverse switch.
7/17/2017 11:47:54 PM • Hampton Bay... • Answered on Jul 17, 2017
2answers
5 wire, 4 speed Zing Ear Switch ZE-268S5
6/24/2017 10:34:40 PM • Hampton Bay... • Answered on Jun 24, 2017
2answers
Ceiling Fan Light Chain Broken; Zing Ear
It's actually a very easy repair. Those pull chain switches are very generic and can be found at home depot or any hardware store for about $3. As far as changing the switch there are only 2 wires to connect and there is no incorrect combination to reconnect them. I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
6/24/2017 10:32:38 PM • Hampton Bay... • Answered on Jun 24, 2017
2answers
The globe for my Hampton
5/6/2016 6:08:57 AM • Hampton Bay... • Answered on May 06, 2016
2answers
Hampton Bay Ceiling Fan
Are you talking about a Hampton Bay ceiling fan product. Is there a label stick attached to the top main housing unit that indicates the model & UPC #. If it;s a Hampton Bay...
4/19/2016 9:25:05 AM • Hampton Bay... • Answered on Apr 19, 2016
2answers
Fan works fine, lights don't. Could it be the remote?
Had this happen to me and it was a hunter fan. Similar problem. Fan worked,lights went out. Took light bulbs out, lowered the light fixture. Tested power coming from the ceiling to the quick connect pins for lights. The power was good. So the Problem's in the light kit. Turns out the government requires all new fans to have certain wattage to lights, set at 190. So 3 60w bulbs or 4 40w. Inside the light kit is a limitor hooked to the black power wire coming from the quick connect,It is smaller wire and mine was pink into limitor and white coming out. Not very big. This went bad so i called Hunter, sending new light kit, but I just wired straight black to black wire bypassed that limitor and lights work fine
1/21/2015 6:42:19 AM • Hampton Bay... • Answered on Jan 21, 2015
Hampton Bay 24750 Huntington III Ceiling Fan Logo
225 questions posted
Top Hampton Bay Dryers Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hampton Bay Dryers
  • Hampton Bay Dryers
Most Popular Question
looking owners manual hampton bay
  • Dryers
