20 Most Recent Kenmore 3/4 hp Food Waste Disposer Questions & Answers
How to remove garage disposal shreeder
Not sure how to take apart disposal: http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/15/2014 5:02:15 AM • Kenmore 3/4 hp... • Answered on Aug 15, 2014
All of a sudden I am hearing a clicking noise and I can't find anything stuck or loose. It is rotating but making this noise,
Disposal parts get loose... as long as disposal is working, it is ok Clean out with vacuum cleaner to remove stray parts etc http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
8/15/2014 4:42:50 AM • Kenmore 3/4 hp... • Answered on Aug 15, 2014
Kenmore disposal turns on for 15 seconds then stops,
Don't install automatic start disposal: http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html Gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
7/26/2014 12:03:36 AM • Kenmore 3/4 hp... • Answered on Jul 26, 2014
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor See if cutter disc located inside disposal can be moved and rotated using broom stick: If disc rotates freely, then try motor again... if still hums, then replace disposal http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html Gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3/26/2014 3:54:15 AM • Kenmore 3/4 hp... • Answered on Mar 26, 2014
Our new kenmore garbage disposal shoots the water up rather than sucking it down
Check the drain is not clogged. Does sink opening have splash guard? Check that plumbing is vented as required by code: http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow Gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3/23/2014 9:41:58 PM • Kenmore 3/4 hp... • Answered on Mar 23, 2014
Where can I find a replacement part for my
Many parts are not available:Copy following link for resources:http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.htmlGeneh If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/10/2013 12:52:01 AM • Kenmore 3/4 hp... • Answered on Oct 10, 2013
Replace garbage disposer shredder plate
http://www.manualslib.com/manual/85405/Kenmore-Garbage-Disposal.html#manualIf the last manual wasn't the right model, this one might be
5/26/2013 12:56:55 PM • Kenmore 3/4 hp... • Answered on May 26, 2013
Replace garbage disposal shredder plate
find the solution in the manual here:http://www.manualslib.com/manual/85404/Kenmore-72785.html
5/26/2013 12:55:08 PM • Kenmore 3/4 hp... • Answered on May 26, 2013
Replace garbage disposal shredder disc
Which direction does disposal blade turn?For example when looking straight-on at the nut holding power saw blade, the blade rotates counterclockwise, so the nut is reverse thread.Most disposals are not made for repairshttp://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.htmlAdd a comment and say where you are getting the parts and which model If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5/26/2013 10:24:19 AM • Kenmore 3/4 hp... • Answered on May 26, 2013
Sinkmaster 850 Garbage disposer. I have to unplug my Sinkmaster 850 to stop it the switch isn't working.
Question edited for clarity. Question moved from Cars and Trucks. Parts suppliers and the maker. https://www.google.com/search?q=sinkmaster+850+replacement+parts ..
4/12/2024 5:52:32 PM • Garbage... • Answered on Apr 12, 2024
2answers
Garbage disposal electrical shock.
Are you sure it wasn't a static electric shock, rather than AC? If you live in a dry climate, or in a cold climate without a humidifier, and you may have walked across a carpet, it could have been a spark of static electricity. Especially if it hasn't reoccured.
4/12/2024 8:40:38 AM • Garbage... • Answered on Apr 12, 2024
3answers
How to replace a Garbage disposal
If you buy a similar model from the same manufacturer, you can leave the sink fittings in place. Unplug the power and disconnect the waste pipe. Undo the bayonet fitting securing the waste disposal unit to the sink fitting. Fit new unit to sink fitting, reconnect waste pipe and power. Run the unit with plenty of water to check for leaks. Job done.
11/2/2022 7:28:51 AM • Garbage... • Answered on Nov 02, 2022
Removing viking 1030 garbage disposal
5/21/2022 11:43:46 PM • Garbage... • Answered on May 21, 2022
How do I unclog a T-1060 Waste Disposer
TURN OFF POWER before sticking your hand in.!! But first check the reset button underneath the unit. Also, try to rotate the spinner with hex key usually provided. garbage disposal 2-r5bj5m104gwgi1atksjipnx0-5-0.jpg garbage disposal-r5bj5m104gwgi1atksjipnx0-5-2.jpg
1/17/2019 7:14:36 AM • Garbage... • Answered on Jan 17, 2019
2answers
What is perspective of waste management by
Drink beer and then recycle glass bottle or aluminum can Then research recycling route for all recycled and non-recycled waste products If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/4/2018 10:41:22 AM • Garbage... • Answered on Dec 04, 2018
Does insinkerator have a start capacitor?
Yes... all motors have start capacitor .. ''Without a start capacitor when voltage is applied, the motor would just hum''
10/11/2018 5:44:15 AM • Garbage... • Answered on Oct 11, 2018
Kenmore 3/4 hp Food Waste Disposer Logo
13 questions posted
Top Kenmore Garbage Disposals Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kenmore Garbage Disposal Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Garbage Disposals
Most Popular Question
kemore 3 4 hp disposal reach under hold
  • Garbage Disposals
