20 Most Recent Tenma ZD-931-I Replacement Soldering Iron Questions & Answers
2answers
Burned resistors
I have the same problem with the Mighty Mig...Did you find these resistor values?
3/28/2024 2:45:54 PM • Welding Tools • Answered on Mar 28, 2024
Iron Force 95 Welder. It won't start up at all. I'm not sure if it has a fuse, or not. It's an Iron Force 95.
Question edited for clarity. Normally on the back or hidden inside https://www.google.com/search?q=iron+force+95+welder+fuse+location Seems to be an unknown make. Try the link where you live https://www.google.com/search?q=iron+force+95+welder+manual ..
1/7/2024 2:07:55 AM • Welding Tools • Answered on Jan 07, 2024
Getting a tip save error on my Millermatic 350P. Does anyone have any experience dealing with this issue?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjVzsuLuK6DAxUrtokEHT4aAJYQFnoECC4QAQ&url=https%3A%2F%2Fforum.millerwelds.com%2Fforum%2Fwelding-discussions%2F28129-millermatic-350p-help-3-error&usg=AOvVaw0mooQgzhw6_QIiLM08bRKh&opi=89978449
12/27/2023 1:13:52 AM • Welding Tools • Answered on Dec 27, 2023
Field excitation
need a model number
12/27/2023 1:13:03 AM • Welding Tools • Answered on Dec 27, 2023
I looking for an owners manual for a matco mig welder wow 1 modal 117-044
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiBkJzkt66DAxVFjokEHZA2A20QFnoECA8QAQ&url=https%3A%2F%2Fwww.matcotools.com%2Fproductassets%2Fweb-documents%2FMG260D_InstructionManual_01.pdf&usg=AOvVaw2tkZdBH07pWjU9d2XVNcYh&opi=89978449
12/27/2023 1:12:23 AM • Welding Tools • Answered on Dec 27, 2023
Century 100 wire feed welder free download manual
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX5_3Gt66DAxVCC3kGHUEmCY0QFnoECA0QAQ&url=https%3A%2F%2Fwww.manualslib.com%2Fproducts%2FCentury-Wire-Feed-100-4113584.html&usg=AOvVaw3kmdPZSNde6Hkk_kq3bVxZ&opi=89978449
12/27/2023 1:11:13 AM • Welding Tools • Answered on Dec 27, 2023
Looking for manual on Stud welder SW2200TF please or video hou to set up,thank you
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjhsbe6t66DAxVcj4kEHQqDAU4QtwJ6BAgVEAI&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D-Yofk5RtRzw&usg=AOvVaw08DLYmdnw6B1gvIXBWER-7&opi=89978449
12/27/2023 1:10:47 AM • Welding Tools • Answered on Dec 27, 2023
Wf2000 wont turn on even though there is power to unit, and threw on off switch
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjGquqZt66DAxXRC3kGHfy6CF8QFnoECBQQAQ&url=https%3A%2F%2Fwww.justanswer.com%2Fhvac%2Fdotuh-trying-turn-pilot-light-wf2000-braemar.html&usg=AOvVaw3JUrr_Sxt5wXE6z2GGYWnn&opi=89978449
12/27/2023 1:09:42 AM • Welding Tools • Answered on Dec 27, 2023
Deltaweld 350 with help 700 code ?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiJm8Xqtq6DAxUvrokEHSvtAyUQFnoECA4QAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft29927508-deltaweld_350_help_100_code&usg=AOvVaw1Zz2ud-ECJTvyBdf5Zm-bJ&opi=89978449
12/27/2023 1:08:15 AM • Welding Tools • Answered on Dec 27, 2023
What's the difference between Soldering Paste and Flux Paste?
https://electronics.stackexchange.com/questions/309954/solder-paste-vs-solder-flux
11/23/2023 3:04:57 AM • Welding Tools • Answered on Nov 23, 2023
My clarke 100en will not strike an arch ...is there a wireing diagram that shows were the wires conect inside from the trigger button
To check if there is a signal from the switch on the gun, depress the switch and the wire should start to move out. If it does, the main board has a fault, if it doesn't, it may be a faulty switch.
10/29/2023 8:10:46 AM • Welding Tools • Answered on Oct 29, 2023
2answers
Thermal Dynamics Cutmaster 25 Plasma Cutter. How to change to 110 volts please.
Question edited for clarity and order. You can't. It is 400 volts - 3 Phase.
Cutmaster 25 Manual Plasma System
https://www.westermans.com > victor-thermal-dynamics... 25mm genuine cut, 30mm maximum cut, 38mm severance; Input: 3 ph. 400V 50/60Hz 20A; Output: 80A @ 40% DC; Front panel LED's indicate status conditions for ... https://www.google.com/search?q=Plasma+cutter+thermal+dynamics+25 ..
9/14/2023 4:51:49 PM • Welding Tools • Answered on Sep 14, 2023
2answers
How to set up welder or aluminum tig welding
If you want to weld aluminium with a welder, your machine must be an AC/DC welder, then you will use only AC to do the weld, but as well you must have a contineous high frequency and according to what thickness you want to weld a water cooling argon torch wont be a luxury
5/21/2023 6:30:35 AM • Welding Tools • Answered on May 21, 2023
Migomag 220. Why won't my Migomag 220 arc?
Power supply short circuit, it blew the fuses out when it let go. https://www.google.com/search?q=migomag+220+no+arc ..
4/23/2023 6:20:45 PM • Welding Tools • Answered on Apr 23, 2023
Marquette Model 64 Farm Welder wiring diagram please?
Question edited for a lot more clarity, 'make model (what it is)' in the correct order. The thing about Speech to Text, is that you MUST go back through it and add punctuation or it all runs into one sentence. I did that for you as well into what I think you thought you were saying! This is an antique from the early 1950s. There is a picture of the inside wiring here https://weldingweb.com/vbb/threads/703256-Old-Marquette-Welder-wiring-question Manual for a Model 60 and 60C https://www.ebay.com/itm/115540831572 More here https://www.google.com/search?q=Marquette++Model+64+Farm+Welder+wiring+diagram ..
3/19/2023 3:08:29 PM • Welding Tools • Answered on Mar 19, 2023
How do you set this welder up for TIG?? The user manual is absolutely useless!
'this welder'. The one that only you know what it is?
11/28/2022 1:25:58 AM • Welding Tools • Answered on Nov 28, 2022
SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
11/24/2022 10:16:49 AM • Welding Tools • Answered on Nov 24, 2022
Tenma ZD-931-I Replacement Soldering Iron Logo
1 questions posted
Top Tenma Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Tenma Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
Tenma Welding Tools
  • Tenma Welding Tools
Most Popular Question
purhased tenma 21 1590 digital solder
  • Welding Tools
