20 Most Recent
Kodak EasyShare Printer Dock Series 3 Questions & Answers
Kodak easy share printer dock 3
sounds like its only receiving half the data. try these step... uninstall printer from your device... reinstall printer to device... if youre using a smartphone or tablet, switch to a pc... press and hold the cancel button on the printer... turn it off for 60 seconds then power it... run the nozzle cleaner function, then try again
It only prints half of the picture. How do you
Hi
The printer driver is corrupted and needs to repair it by adding new printer with the same printer name and set it as default. Then delete the old printer icon. If prints the test page, then it solves your problem.
If still not working, uninstall and reinstall the printer driver which will refresh the printer driver itself. then set up the printer again.
Regards.
Printer Dock 3 Print Problems
Unfortunately you may have to force feed the paper through as the printer is trying to pull it, it works but you have to stop pushing once it takes the paper!
Need to download manual for
The manual for a Kodak EasyShare printer dock series 3 can be found here: http://resources.kodak.com/support/pdf/en/manuals/urg00367/PD3_GLB_en.pdf
Printing Issue
It has dust or built-up goo on the feed switch. Try some canned air
Picture prints with red tint
Sounds like the colour cartridge is either empty or you have blocked cyan and yellow printheads. If so, refer to the user manual for instructions on how to clean the printheads. This is a common problem on any inkjet printer which isn't used regularly and is caused by ink drying in the nozzles.
