20 Most Recent
Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Questions & Answers
Leak around the door seal
the seal might look ok but don't forget the seal could crack on the bottom, any time the washing machine stops and the water settle
there's more water at the bottom half so the bottom of the seal takes more abuse. so I would replace the sealer and if you can buy a little thicker one.
Samsung waching machine won't drain
If you don't have the DIY skills to fix what is probably the drum bearings or water pump gone then an appliance engineer is your next bet. Is there excessive movement in the drum itself? Does it turn smoothly? Switch off at the wall, remove the access panel and see if the drive belts are OK. The grinding noise could be a coin trapped between the drum and the drum casing. None of this is an easy fix. Keep in mind the age and usage if you get an estimate, maybe cheaper to buy new?
How to clear codes
i found this in another place
Quick Test Mode
Note: This test erases all faults and memory:
To enter press Spin, Soil, & Power
simultaneously with the power off.
1. All LED's light up and the washer beeps as it
enters the Quick Test Mode.
2. The unit displays the software version for a
second then clears the EEprom.
3. After the displaying the software version, LCD
will display Model information.
If EEEE is displayed the PCB assembly is defective.
For production up to 03/31/2009 Serial **S3**
4. When the version is displayed. Press the following
keys to test the various components.
Effective 4/1/2009 Serial **S4 ** a change was
made.
4. After the displaying the software version, turn
the Jog dial CCW to display "F4". Press the following
Press Temp Key to cycle through the Water Valves in
this order: Cold Main, Bleach, Cold Main & Bleach for
Fabric Softener, Hot, then off.
Press Spin Key to test Motor circuit.
Press Signal Key to test Drain Pump
Press Soil to test door lock - unlock circuit
