20 Most Recent
Advent LC-20H15A 20 in. EDTV-Ready LCD TV Questions & Answers
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
I have a 15 inch Advent LCD TV in my kitchen. I
U have vertical lines for a few second.That mean u tv have a dead board call the T-CON decoders is board.This T-CON decoders board sit at the bottom wright in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Advent DVD player won't turn off
It sounds like you're experiencing an issue with your Advent DVD player not turning off properly. Here are a few things you can try to resolve the issue:
- Check the remote control: Make sure the remote control is not accidentally turning on the DVD player. Try removing the batteries from the remote and test the power button on the DVD player again.
- Check the power cord: Make sure the power cord is securely plugged into the DVD player and the wall outlet. Also, check that the outlet is working properly by plugging in another device to see if it powers on.
- Unplug the DVD player: Try unplugging the DVD player from the wall outlet for a few minutes, then plug it back in and test the power button again.
- Try a soft reset: If the above steps don't work, you can try performing a soft reset on the DVD player. To do this, unplug the DVD player from the wall outlet, wait a minute, and then plug it back in. Press and hold the power button on the DVD player for about 10 seconds, then release it. The DVD player should turn off.
- Check for a hardware issue: If none of the above solutions work, the issue could be caused by a hardware problem with the DVD player. In this case, you may need to contact the manufacturer or a repair professional to have the DVD player serviced.
It's possible that one of the above solutions will resolve the issue, but if not, it's best to consult the DVD player's manual or contact the manufacturer
I have hughes remote i need program code for advent tv model#Q2035A
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the
brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
